Question about heater core hoses
Alright so I know the heater core hoses send hot water to the heater so the heater would heat up. If I decide to unplug these 2 tubes (just don't ask why, that's not the point here), what would be my next course of action? I know I can't just leave them hanging since that might warp the head. Can I plug them into each other? That way the water/coolant travels back without having to travel through the heater. I took a picture and kinda drew a line to connect them so you know what mean.
Would that work? Thanks in advance
http://s93.photobucket.com/user/Call...lt57p.jpg.html.
You should be able to loop them together using a different/less complex route. You want as few kinks as possible in the flow.
I am going to ask why. There is no reason any car should not have heat/defrost no matter what its being used for.
You already got answer about the hoses - yes, you can bypass the heater core.
(Not going to mention again about the danger due to no defrost...good luck)
Anyway, don't forget that you're going to have residual coolant still hanging out in the heater core if you just pull those lines off and connect them together. Don't forget to plug the inlet/outlet holes on the firewall side to avoid debris getting in there and contaminating the core and causing your water pump to hate you after/if you reconnect and recirculate everything.
LeeC
Mar 5, 2012 08:34 PM
