PCV valve replacement parts
Old Oct 27, 2016, 01:57 PM
aamoedo's Avatar
Thinking about replacing my PCV valve because I'm at 70k and it's never been done. Are the grommet and gasket necessary?
Old Oct 27, 2016, 02:09 PM
heel2toe's Avatar
If they aren't leaking then no point in replacing those as well. Unbolt the old valve, pop in a new one and call it a day.
Old Oct 27, 2016, 02:49 PM
aamoedo's Avatar
Thanks!
Old Oct 27, 2016, 10:30 PM
barneyb's Avatar
WARNING!
I bought a replacement PCV valve at Advance Auto. I knew the valve is supposed to seal when there is pressure in the intake manifold. Otherwise the turbo is pressurizing the entire crankcase. Just to check I blew air through the replacement valve and air whistled through both ways. I'd suggest you either go OEM or do this check.
Old Oct 27, 2016, 10:36 PM
Pal215's Avatar
Originally Posted by barneyb
WARNING!
I had the same experience with Autozone pcv valves. My 30,000 mile old oem valve was in much better shape than a brand new leaky autozone valve.
OP, when replacing these, only go with oem.
-pal215
Old Oct 27, 2016, 10:45 PM
barneyb's Avatar
Yeah, I'm still running my original at 110k. I'll inspect it again at timing belt time but it looked and worked perfect a couple of years ago.
Old Oct 28, 2016, 09:22 AM
aamoedo's Avatar
I picked up an OEM. Thanks for all the info.
aamoedo
Apr 24, 2013 10:53 AM
DrDeC
Apr 6, 2012 07:19 PM
anthonyrb98
May 2, 2011 03:31 PM
berkel
Jul 8, 2010 01:56 PM
smokedmustang
12
Sep 17, 2007 02:25 AM
Quick Reply: PCV valve replacement parts
