Twin disk vs single disk for a daily? And why?
Done some research cant really find anything conclusive. 300whp/wtq car. Daily. Beat on the car pretty hard. I've heard twin disk from multiple people and a good shop. Heard that shep says always do at least a twin disk no matter what. On the other hand, I've heard people say twin disks are designed to allow clutch drag, are designed to have the trans and clutch serviced/freshened up often. Heard people say id rather keep replacing clutches than transmissions (in favor of the single disk). Problem is no one can ever really explain why. Id rather spend the money now instead of having to soon down the road again. For me, its between the act 6 puck and an exedy twin. Which should i go with and why?
edit: 305/297 whp/wtq on a mustang not that it makes a huge difference i thought id note that
at 300/300, i would run an act hdss. Good drivability, good life, and they are cheaper than a twin by quite a bit. This will also be far more street friendly than a 6-puck.
I ran an ACT 6 puck (daily driver) and it lasted 65k miles. Now I'm on ACT HDSS. The 6 puck was a little harder than the single disc to be smooth but it's do able. Hearing the twin discs last about 30k miles(sure there is a give or take for everyone in mileage, read some lasting under 10k miles also) before you have to replace the clutch discs(i'm sure someone else can chime about longevity) but if that's the case then i would just go single disc. A lot cheaper, last longer(if driven right) and does the job well. No need to spend big bucks for something your car doesn't even need. My cars 340/340 also.
People always recommend twin disks because 85% of evo owners will never exceed the capabilities of a twin. So basically you can throw everything you want at a twin and it will take it. It's also easy for someone to tell you that a twin is what you need when they aren't paying $1800 for one.
I had an exedy twin in my car at 300/300. It was ok, kind of brutal for daily driving and taking off on hills. I decided I would much rather have something smooth and make daily driving more enjoyable. I got a comp stage 2 clutch for like $500 and change. And I'm now making 503/415 on this clutch. Driveability is way better and the clutch has no chatter like the twin did. Twins are usually overkill, which isn't always a bad thing, until it compromises other aspects of the car.
Only benefit I see in a twin besides the obvious torque holding advantage is being able to launch them alot harder than most singles. So if you race and launch alot then that's something to consider.
I have an act hdss with a streetlite flywheel and i started grinding 4th with ~11k on the trans clutch and flywheel (to be fair i THINK its my slave adjustment, it doesnt make any significant movent until the very top). I do launch the car often hence why i want at least a 6 puck
I runner exedy twin, now triple disc clutch every day, pedal is a lot easier to push than single disc 6 puck. In multiple disc clutch packs Clamping force is divided in to 2 or 3 discs. Same pressure plate. So ur getting a lot better pedal effort and torque and power capabilities compared to single disk.
I'm a fan of single discs. Everyone I know with a twin is always needing to adjust or replace something. They seem like a lot of trouble. Most people that I've seen that have them don't need 'em, so that really confuses me. I refuse to overpay and over-complicate for stuff that is way more than I'll need (how many people actually ever end up with 400+ftlbs of torqe?).
At your torque rating, you can do an ACT HDSS and be fine. It drives like stock, is reasonably cheap, and grips really well. Pedal action is light, too. If you are into drag racing, I'd probably suggest a sprung 6 puck unless you are really good at slipping clutches.
Keep it simple and don't over spend. That's how I roll. LOL
IzzyRS (Dec 25, 2016)
300 bux for a flywheel??? They are very proud of that chunk of metal. Have yours turned.
For my stocker I went all OEM when it was time for a clutch. The clutch I got compared to what was in the car when it came from the assembly plant is the difference between night and day. Things are always changing, mine has been in two years now, but this clutch is everything I could want in a clutch. The original liked to grab and chatter but it went 90K.
Keep it simple.
300 tq is a street car. So use a street disk.
Dont need a "track" disk in a street car.
I recommend a act HDSS.
Street for street.
Track for track.
A dual clutch is overkill for a daily w 300 torque.
In fact the twin disk can put unwanted pressure on your crankshaft thrust washers.
Street for street.
Track for track.
