4g64 timing help
However, in response to an earlier post about the evo notch being for evo 1-4, i have seen fidenza gears vary when layed on top of or beneath a oem evo 8 gear, while lining up the marks & cogg's of the gear, you can easily see if the dowel hole & center bolt hole is lined up. This is with the fidenza gear set to zero...
Anyone else get a CEL with a 4g64 and MIVEC? I forgot the code right now, I can check it in a bit, I think it was a P0300. Shop says that's just how the timing is for this thing.
Car's fine, but can't smog it like that. Looks like mrfred has a thread on disabling that one.
djikonatx
60
Sep 13, 2013 11:08 AM
mrboost05
Mar 6, 2013 09:58 AM
bostonhatcher
26
Oct 10, 2012 08:33 AM
djikonatx
164
Jun 20, 2012 08:02 AM
