Situational Ticking Sound
Old Feb 20, 2017, 04:00 AM
NoReason's Avatar
Hello,
I've searched and searched the forums and saw a lot of ideas of what my sound could be and have tried everything. The engine has 500 miles on it since being rebuilt and has made this sound since the 1st mile; I feel like it's getting louder but it could be my paranoia. Everything is new. My ticking noise comes on between 3-4k RPMs and only while it's in vacuum and light throttle. It doesn't tick at idle, while the car is stationary, nor above 4k rpms. Also, I'm running GSC no tick lifters. I'm going to buy the specialty tool to remove the lifters and rebleed just to be sure. No exhaust leaks, no cat, manley rods and crank, wiseco pistons, gsc s2 cams w/springs, new crank pully, new belts with tensioners, cam timing is perfect, wastegate is tight with a new turbo. No EGR and nor brackets behind the intake manifold. No balancing shafts. New Exedi Twin Plate clutch. Fresh transmission rebuild. All fluids are fresh and topped off. New Spoolinup COPs. Knock sensor isn't picking anything up. Fresh 10w-30 oil this morning. Is there anything I'm missing that I could check before I tear out the bottom end again? 2005 SSL Evo 8 fyi.
I will add a video soon.
Old Feb 24, 2017, 08:38 PM
nor11384's Avatar
have to hear it but do you have an ebc? mines ****ed with me for a while until i realized it was ticking...its a rapid tick...
striderx88
Feb 23, 2012 10:56 PM
zeus1
Jan 18, 2007 01:05 PM
evo_skillz
Nov 23, 2006 02:37 PM
MysticMyth
Lancer Troubleshooting
May 12, 2005 10:33 PM
weightless
Jun 24, 2003 08:30 PM
Quick Reply: Situational Ticking Sound
