im stumped guys. looking for help
i keep getting
P0172 System too rich
P0134 Heated Oxygen Sensor (Front) Circuit No Activity detected
i have replaced the front 02 with three different brand new sensors and it wont fix the problem what could be other causes/????
car is running at idle 11.8 on average on my afr
Anyone have any input?
inspect the wiring harness for damage.
both, if you have a helper you can unplug the ecu and run a continuity test with a multimeter from the connector under the spark plug cover all the way to the pins on the ecu harness. A good visual before that could turn up your problem too.
I would recommend just repairing the harness. The only wiring you aren't suppose to repair/splice is the airbag stuff because the resistance tolerances are so tight and the risks are very high if something goes wrong.
https://www.obd-codes.com/p0134
code P0134 may mean that one or more of the following has happened:
Bad O2 (oxygen) sensor
Bad heater circuit in the O2 sensor
Wiring or connector to the sensor frayed / broken
Blown heater circuit fuse
Holes in the exhaust system
PCM failure
Those are apparently the causes of the P0134 code. I'll check the Service manual when I get a chance and see if it has any other guidance on this specific code.
PCM failure
Waferz
Mar 14, 2017 01:00 PM
fit4130bmx
Feb 29, 2012 05:14 PM
EvoTech
11
Oct 30, 2007 09:40 AM
Kevin Knight
16
Apr 20, 2007 09:00 PM
