Tps help
Old Feb 26, 2017, 08:33 PM
kamote2000's Avatar
Tps help
Having problems with my tps for the longest time, ive set it to 13.33 but still get the P0122 code on random i have set it over and over again but after a day or two once i start it up in the morning code keeps coming back. Ive replaced the tps sensor 2 times already with a brand new oem unit but problem still remains. every time i try to clear the code i check it on evoscan but it would read at around 3-4% but i have set it manually at 13.33 the day before and i never touched the tps after it has been set properly. hope someone can help me out. thanks
Old Feb 26, 2017, 08:58 PM
4b11slayer's Avatar
13.3% is good. 3,4% is way off.
Old Feb 27, 2017, 01:18 AM
kamote2000's Avatar
Yeah but thats the problem it doesnt stay at 13.33 it goes down to about 3-4 on cold starts
Old Feb 27, 2017, 07:16 PM
4b11slayer's Avatar
Hmmm. Maybe low battery voltage?
Old Feb 27, 2017, 07:51 PM
Teal2nnr's Avatar
When you look at the voltage is it steady or moving around?
Old Feb 28, 2017, 01:08 AM
kamote2000's Avatar
It slowly moves around about +/- 2 or 3%, so if i start it up and the cel turns on the tps reading is at 4% when it changes it would go up slowly to around 6% but it would never go back to 13.33 as i have previously set the day before.
Old Feb 28, 2017, 01:09 AM
kamote2000's Avatar
Battery is good 14v at idle
12-13v before cranking
Old Feb 28, 2017, 01:11 AM
Raceghost's Avatar
TPS is going out. Order a new one, can find official Mitsu with part number for $50
Sorry, just reread your post. You could have a ground issue with that sensor. Log the sensor at accessory, and see what full open reads when it does this.
Could be an issue, not sure yet, with your ECU. Most likely it is a ground issue.
Rarely, but heard it happen that a plug to the ECU, the little pin comes loose in the plug, and doesn't seat tight, however, this would be just a random check.
My money is on a ground wire, loose in the engine bay. Any other weird electrical anomalies?
Old Feb 28, 2017, 01:58 AM
kamote2000's Avatar
No other electrical problems just the tps, do you think i should replace the connector? Cant seem to find any breaks on the wires right after the connector.
Old Feb 28, 2017, 02:37 AM
Raceghost's Avatar
Could be that connector specifically. Those connectors are male on the sensor side, and female clamps on the pigtail side. Might be a loose clamp on that connector, check it and see if you can close it possibly. Also check the wire side of the connector and see if one of the pins wiggles.
Old Feb 28, 2017, 03:35 PM
kamote2000's Avatar
Ok will look into it later
Evil Evolution
30
Jan 11, 2013 09:22 AM
Evil Evolution
Midwest Region
Jan 4, 2013 09:05 AM
EvolNinja
Sep 29, 2008 07:29 AM
giangi
Sep 19, 2005 10:09 AM
Quick Reply: Tps help
