Can I replace mani > turbo gasket without removing turbo or elbow?
Hi everyone. Is it possible to remove the manifold to replace manifold to turbo gasket without removing the turbo or undoing the elbow? Long story short, my turbo studs on the elbow side are screwed and it was blowing. I managed to get that side sealed but in the process got a leak on the mani to turbo side. I'm going to replace the turbo etc at some point so don't want to put much money or effort into sorting this small leak so I was wondering if I can possibly get the manifold off to replace the gasket without messing with the elbow > turbo gasket? To make it even more complicated, I've got a custom exhaust so the elbow and DP is one piece which will restrict movement on that side even more I guess
Thanks
Thanks
The exhaust is a custom 2 piece system and the join is past the 2nd crossbar, so i'm not sure how much wiggle room there will be. Another thought I had was removing the turbo to manifold studs? They're nackered anyway so maybe getting them out is a good idea
Drop both crossbars, and you can drop the turbo, downpipe, etc to the floor.
Unbolt Turbo from Manifold, and it will be able to drop.
Unbolt Manifold from head, and wualla, your done.
R&R of course.
1fast97gsx
Jul 21, 2014 04:15 PM
xXANCHORMONXx
Jul 18, 2012 01:44 PM
Boost3dxEvO
13
Oct 2, 2008 12:52 PM
evilevo22
Dec 28, 2007 02:16 AM
