Stock valvetrain with Kelford cams - causing a bad bog at dragstrip?
Hey guys. First off I want to give little bit of info about my car.
It's a 2006 Evo 9. Little under 54k miles. Full bolt ons, FP Red, Kelford 272 cams, stock springs & retainers, stock bottom end. Makes ~504/402 on a dynojet with e85 @ ~28psi.. ecu controlled boost.
So the past couple times visiting the dragstrip I noticed after winding out each gear and shifting pretty quick the car bogged really bad, at the bottom of the next gear. It would literally lose all power for a split second.. then kick back in full power(almost like spark blowout or a misfire) obviously hurting my times.
For a while i thought it might be spark blowout. But my tuner said to try shifting earlier just to see what happens. So I took the car down the track and shifted right at 7k (my tuner has redline raised close to 8k i believe). The car didn't bog! however, not winding out each gear hurt my mph and ET.
So my tuner thinks that I need to do valve springs and retainers. He thinks that could be causing the bog issue.
I am curious on the forum ninja's thoughts on the matter
Im having the exact same problem. Im making 371 on a stock block and turbo setup with a spoolinup COP and bpr8pes plugs gapped to .2 so im very curious as to what this could be
THmotorsports
Evo 'For Sale' Engine Internals and Drivetrain
67
Aug 2, 2016 09:11 AM
THmotorsports
EvoX 'For Sale' Engine Internals and Drivetrain
65
Jun 29, 2016 10:29 AM
RyanM
28
Jun 20, 2006 12:21 PM
