How to install the spark plug anti-foulers to remove the ses or cel light
Old May 27, 2009, 07:33 AM
  #121
Davo's Avatar
the help brand available in most part stores and they work excellent
Old Oct 14, 2009, 10:11 AM
  #122
MR:PartyPete's Avatar
I've done this when I had a Neon srt-4. I don't think your suppose to drill it all the way out. Just enough to get the sensor to be secure. Otherwise if your drilling it all the way out is it really much different than no non-fouler?
One long one Part#42002 should be good. That's probablly why two shorter ones Part#42009 are working also.
Old Nov 12, 2009, 06:03 PM
  #123
prodystopian's Avatar
I tried to do this fix today on my 03 and the O2 Sensor is stripped and I couldn't get it out. Any suggestions?
Old Nov 12, 2009, 06:14 PM
  #124
detroit pistins's Avatar
did u strip the hex head on it or the threads? and did u use an o2 sensor socket? u can find them at autozone for $8 btw.
Old Nov 12, 2009, 06:36 PM
  #125
The Hex head. Nope, I used a wrench (can't remember the size) and then tried vice grips. I had no idea they sold those. You mean this:
http://www.autozone.com/autozone/cat...questid=171992
Old Nov 12, 2009, 06:42 PM
  #126
its one of these
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
but the one u found might work too, iam just not familiar with that one.
Old Nov 30, 2009, 08:07 AM
  #127
Joeekrub's Avatar
I was getting the P0420 code... so I did the fix with the TWO antifoulers and after 60 miles I'm now getting the P0037 code... Are these connected? Will it clear itself after some more driving? Any suggestions
Old Dec 3, 2009, 09:01 AM
  #128
Evo666's Avatar
Did you clear the ecu the first time? If not, then do it.
Old Dec 3, 2009, 09:55 AM
  #129
Joeekrub's Avatar
It was reset the first time
Old Aug 6, 2011, 11:09 AM
  #130
mclean02's Avatar
i will try this on sunday
Old Dec 26, 2011, 03:51 PM
  #131
Ignited Alchemy's Avatar
I used this on my SRT4 and on my EVO. I didnt drill it all the way thru. Just enough for the o2 to clear inside.
heres the how to on the srtforums.com
http://www.srtforums.com/forums/f75/...er-mod-398390/
Old May 18, 2013, 09:04 PM
  #132
000
000's Avatar
HAD po421. Tried the fowler and it works !!!! Thank you!
Old Jul 26, 2013, 06:55 PM
  #133
joseph146's Avatar
Im gonna try this tomorrow tomorrow after i install my dp and testpipe hopefully it works.. 2 anti foulers just to be sure no ses light will come on.
Old Jul 30, 2021, 08:19 AM
  #134
High_PSI's Avatar
I've been running this setup since 2003. No CEL.
Benson830
Nov 8, 2016 09:32 AM
Gfunk101
Jun 22, 2014 10:46 AM
d4vid
Dec 23, 2010 07:56 AM
bhamEVOguy
11
May 4, 2007 01:32 PM
05blue8
Apr 24, 2007 01:00 PM
Quick Reply: How to install the spark plug anti-foulers to remove the ses or cel light
