How to fix a stuck sunroof
#106
I finally get to make a contribution. lol A
I just did this one hour before this post and it worked second try.(skipped a step first try) Hope this works for you guys.
https://www.evolutionm.net/forums/ev...ml#post8158403
#107
Im confirming this. It works.
#108
great write up everything worked well mostly for me, im a tard and somewhere along the line i only made it work like...1/2 way. it opens all the way up if i hold it. It closes but i have to push it like 20 times and wont just lift up. I guess that beats not working at all heh.
#109
#110
i have a feeling my motor is starting to go out because its really weak but idk i realign it by pushing it back and making the motor go all the way back and when i try to close it it goes halfway and seems llike it gets stuck on something :/
#112
ok so i finally got around to fixing my sunroof...and let me tell you that cajun power's instructions are great...i follwed them step by step and everything worked the way it was supposed to work....about that one screw thing holding the motor in place.....when i dropped my roof liner i had 2 screws come rolling out so i suspect that the screws came loose and fell out causing the motor to fall off track....anyways i put all three screws back in any everything works great....hes right about the visor clips being a pain but everything else is relativley easy if you have some patience....once again thansk for the write up Cajun!!
Either way phenomenal write up, much appreciated because I was biting my nails prior to searching for your write up when I was just trying to figure it out as I go. Some things were self explanatory but once I got to the front portion to those damn clips I thought I was border line S.O.L.
Thanks again!
#114
Thanks so much for the writeup!!! Saved me this morning. I was able to fix it in about a hour. It sounded like crunching metal! I only had one screw holding the motor in also lol
#115
My sunroof broke yesterday.
Found these instructions started on it this morning at 11am, finished at 11:45.
I only found 1 screw dropped and 2 were loose.
You only have to unclip the rear half of the liner.
I will also confirm that the initialization instructions work perfectly.
#119
Picture of what exactly?
I used this guide to take apart mine but I drive an 04 Ralliart Lancer.
I was able to fix it, long story but it was not what everyone else is experiencing. In either case, I still have the top completely off and can take pics if it's the same.
