In-dash dvd monitor
In-dash dvd monitor
I am planning on purchasing a clarion in-dash dvd palyer(Monitor ). My main question is if I will need to run a wire to the battery for constant power. I have had a hard time finding a definite answer.
My plans were to use a wiring harness. Install a ground to the e-brake and a bolt behind the head-unit(ground ) with a switch to turn this safety feature on and off. Now back to my main question, which is will I need a constant power supply from my battery.
Also, I have searched a lot on this subject so please either answer the question or critique my installation plans. This is for the entertainment of passengers and for excellent i-pod interface, so please do not flame me for doing this mod as opposed to a power mod.
Thanks
Thanks
if you are planning on running the internal amp (from the clarion control unit box) it is not a bad idea to run a heavier wire from the battery. it wont be difficult, just run it on the pass. side, mount the control box under the pass.seat, and your done. i dont think you will even have to extend the harness.....fuse it 12 to 18 inches from the battery. 12 ga. should be ok!
You dont need to, but it definatly wont hurt anything if you do. The only thing that you will benefit from is your lights on your radio wont dim, and you might have better sound quality (this is highly speculative)
I have installed many of the Pioneer 80mp units along with the alpine 9831's which both require constant 12volt source to the battery, and havent seen any major changes.
If it were my car, I would get a good ground and call it a day..
hey thats the one i got in my car!!! well as for me i never ran another wire to the battery i just bought a harness for it so that i dont need to cut anymore wires. you can get a harness in best buy or circuit city, just tell them its for a clarion. Me and my friend installed it and it was a piece of cake. Just follow the instruction what color goes to where. You dont need to run it to the battery unless you are getting subs and there pushing alot of amps..
I installed the Clarion VRX755VD in David's RS which is a touchscreen flipout dvd player. He has had no problems at all. I currently have the pioneer 6400 in mine and have not had any problems either. The only thing that irritated me was trying to get all the wires, rca's etc... back in the small area. David's deck seemed to fit in his car better than mine for some reason. The pioneer units always have a ton of extra stuff on them.
I have done numerous stereo and custom installs on all different kinds of vehicles and never had a problem with the stock wiring going to the headunit. You should be fine!
Jarrod
Buschur Racing Inc.
Jarrod
Buschur Racing Inc.
Jarrod
Buschur Racing Inc.
Jarrod
Buschur Racing Inc.
TrogdorWBL
65
May 3, 2016 02:38 PM
kidneythief13
May 24, 2008 02:57 PM
kidneythief13
11
Mar 5, 2008 03:35 PM
evo86
Sep 27, 2005 11:25 PM
