Greddy EGT help please
i have greddy EGT gauge, i'm trying to install it. everything wire and tap for sensor. their are two wire i can't figure out. already connect the ground, and the power. the other two wire which is ingition and parklight, help please
If you have a turbo timer with a turbo timer harness just follow this
GREDDY
Red wire > Red wire on turbo timer harness (or 12v constant)
Orange wire > Green wire on turbo timer harness (or ign1)
White wire > Buy one of these (you can get them at mejier or an average "super store") > http://www.dlcparts.com/frontend/pro...INE%22&ID=1024
Now go into your interior fuse panel and use your chart to find the picture of a guage or a cluster, trace that picture of the guage (which is for cluster lighting) to the actual fuse, replace the fuse with the product above and tap the white wire into there
ground the remaining wire.
PM me for more help
GREDDY
PM me for more help
FS[Northeast]: Greddy 60mm egt
efaustin
Oct 7, 2015 06:30 PM
