how to wire up headlamp leveler??
Old Apr 26, 2006, 10:56 PM
evo_racer's Avatar
hi i'm trying to install oem headlamps from a ssl into my 06 gsr without HID's, does anyone know how to wire up the headlamp leveler? if i'm correct there are three wires for the leveler, does anyone know they work? thanks.
Old Jul 20, 2007, 04:11 PM
Positron's Avatar
bump
I'm trying to do this to.
Old Nov 4, 2007, 01:41 AM
trinydex's Avatar
is it possible?
Old Nov 4, 2007, 01:44 AM
Travisivart190's Avatar
I would like to know as well.
Old Nov 4, 2007, 06:07 AM
Positron's Avatar
bump.
I think you would need the HID interior leveler switch. But not sure what to do after that since I think you would need to somehow wire that to the hid headlights.
Old Nov 4, 2007, 02:48 PM
trinydex's Avatar
and somehow tie it into the etaks ecu which i think is what controls it. if it were just to the headlight that would be easy.
Old Nov 13, 2007, 11:24 AM
Wallesasuaz's Avatar
it's possible, but you gotta have the harness that plugs into the leveler. Then you gotta run independent lines from harness, to a switch inside the car and use it for leveling the headlights. U can do the same for the foglights as well....
that's what I did. ( the fogs )
I never did the leveler portion... didn't wanna bother w/ it. I just used a phillips screwdriver and inserted from the top of the mechanism and kept turning until the beam was at that level i wanted.
Old Nov 13, 2007, 11:43 AM
trinydex's Avatar
shouldn't you be using the adjustment nut?
Old Feb 21, 2008, 07:13 PM
ajstefanacci's Avatar
so is there a control box or can you wire the switch right to the headlight motor
Old Mar 9, 2010, 11:17 AM
Boricua_Evo's Avatar
Bringing back from the dead, anyone figure this out? I'm trying to convert mine to MR headlights with leveler...
Old Mar 12, 2010, 09:53 AM
U need a completely different harness. not worth it honestly.
Just manually adjust them.
Chunkofhunk
May 5, 2017 03:13 AM
Yota Eater
Mar 11, 2017 06:50 AM
john blaze
Jul 31, 2016 06:56 AM
CottageLifer
Outlander Sport
10
Oct 17, 2015 10:15 AM
ru4real
Mar 5, 2003 07:59 PM
Quick Reply: how to wire up headlamp leveler??
