How-to Perrin 25mm rear swaybar & stout mounts
Old Jan 5, 2007, 09:21 PM
savaho's Avatar
I searched and could not find a how-to on installing the Perrin 25mm swaybar / sway bar so I decided to help others out with one of my own.
How-to install Perrin 25mm swaybar & stout mounts.
1. Remove the nuts holding the stock rear swaybar to the endlinks.
2. Remove the passenger-side rear wheel and then wiggle the top rubber muffler mount off of the hangar as seen below.
3. Remove the bolt holding the muffler up at the rear rubber muffler mount as seen below.
4. Now remove the 2 bolts holding the 3rd rubber muffler mount to the chassis as seen below. This will allow you to lower the exhaust system low enough for the stock bar to be removed.
5. Now remove the 4 bolts keeping the OEM stock bar connected to the car's frame and then wiggle the bar out starting with the muffler side.
6. Once the OEM bar is out, installation is simply reverse of above. Do not forget to lube the rubber bushing that came with the Perrin bar.
Old Jan 6, 2007, 04:59 AM
EVO8904's Avatar
WOW!!! That is a nice swaybar. It appears to be easy to install.
Old Jan 6, 2007, 05:56 PM
t51splbb's Avatar
Very nice write up with pictures,the most detailed I've seen so far.
Old Jan 10, 2007, 02:46 AM
iWant2play's Avatar
savaho,
the holes one the ends of the bars are to increase or decrease the tension inflicted on the bar. furthest out is the softest setting and furthest in is the stiffest.
100% guarantee
Old Jan 10, 2007, 04:25 PM
savaho's Avatar
Originally Posted by iWant2play
savaho,
100% guarantee
Thanks for that information. It would've been nice if Perrin put that in the directions.
Old Jan 25, 2007, 06:50 PM
EvilBlueEvo8's Avatar
can you get those mounts seperate?
Old Jan 25, 2007, 08:03 PM
hondafan's Avatar
yes.
Old Feb 27, 2007, 12:48 AM
7oey's Avatar
Does the perrin sway bar have any clearence issue with any exhausts?
Old Feb 28, 2007, 11:07 PM
Huy's Evo's Avatar
how does it feel around town or at the track
Old Feb 28, 2007, 11:18 PM
newimportowner's Avatar
That looks so much better than the Hotchkis Mount... Perhaps I'm off, but it looks like it is more rigid. I had the Hotchkis on my VIII and did like it a lot on the stiffest setting. anyone else have thoughts on this?
Old Mar 4, 2007, 12:57 PM
MREvolution06's Avatar
Nice write up. Just put my on about 2 weeks ago.
Old Mar 4, 2007, 01:05 PM
Evoryder's Avatar
love perrin
Old Mar 26, 2007, 05:47 PM
trinydex's Avatar
from: https://www.evolutionm.net/forums/sh...d.php?t=245204
Old Mar 27, 2007, 08:36 AM
SICK SPEED's Avatar
Thanka for this info....I am trying to decide on which rear bar to get - I really like the Perrin setup vs. the Cusco........this was a very helpful post
...what other bars did you consider and where did you get yours? $?
Thanks - Sick Speed
Old Apr 20, 2007, 09:01 AM
dj_subculture's Avatar
Are you using the Perrin end links or the OEM?
Quick Reply: How-to Perrin 25mm rear swaybar & stout mounts
