help installing clutch
Insert 500 George Washington's at local performance shop, pick car up next day and 500 miles later vroom vroom...
Those are the 3 steps i am taking. Although i have the tools and man power to do it, its cold in our garage, and no time due to school/work
Good luck with that though man,
Good writeups at the 2 sites...for those of you with 6 speed MR trannys...you will definitely struggle if you try the ramps, limited height access method. If you don't have a lift, get the car as high as safely possible on both ends and have a muscle bound friend to help hump the tranny out and in, plus, loosen or remove motor mounts so you can raise and lower the engine while trying to get the trans to line up with the splined shaft.
i have done clutches on both a 2003 and 2005 both went pretty decent done in 1 day but the trans alignment is the biggest pita of the entire job.... some have issues with the tob coming loose i think thats just hit and miss if u have problems....
Not to bad of an install. Unless its an MR.
Biggest issues were
the retaining ring for the clutch kit.
Kept popping it up when the gear set didn't hit it right.
So aligning the engine and the transmission is the biggest pita.
I suggest using a lift and just lifting that **** up there on your shoulder.
Biggest issues were
DuBBzEvo27
Apr 26, 2015 11:40 AM
