How to boost your octane using various formulas
#63
im not sure what you are asking. The octane after blending would be different, depending on the amount of fuel and the amount of toluene/xylene. if you know the percentage of mixture, you can calculate the octane after mixing.
#65
Example of 30% tolune with 70% pump 93:
0.3*100 + 0.7*93 to determine the final octane,
instead of:
0.3*114 + 0.7*93
any imput??
#72
I don't want to often anyone; Before you use it, you may want to check out 'wikipedia'. The Stuff may be dangerous to your Pump and hoses. Read on toward the bottom.
http://en.wikipedia.org/wiki/Toluene
"Toluene also poses similar problems as alcohol fuels, as it eats through standard rubber fuel lines and has no lubricating properties as standard gasoline does, which can break down fuel pumps and cause upper cylinder bore wear."
#74
http://www.elektro.com/~audi/audi/toluene.html here is another thread
