Sparco Pedals
I have Sparco Grip pedals on mine..
You'll need a driller..
Place the pedal piece on the gas pedal.
Hold still.
Drill one hole.
Put the screw in and tighten it.
Repeat those steps and u r done..
Hold still.
Drill one hole.
You have to cut i bit of the pedal off....I took mine to a shop and they removed the clutch and brake pedals and replaced them with the Carbon Fiber Sparcos....then we realized that the Accelerator pedal doesn't come off, so we cut it down a bit, drilled holes and used tapping screws to hold the CF pedal onto it....Looks perfect!!!
hmm well at least on the lancer you have to kind of twist it then slide it out. It's got a clamp then the metal pole goes through a tunel. I'll try and take mine off tonight and get pics.
AWD_SR71
Apr 4, 2005 03:20 PM
kingkyle
Jan 10, 2005 01:56 AM
