How TO: release throw out bearing
Well since it seems like alot of evo owners have problems with this i figured i would try to help a little.
All of this will be done through the inspection hole in the tranny, i just did it out of the car to you could see it alot better. Make sure you do this before you unbolt the bell housing
Take a flat head and stick it in between the TOB and wedge collar.
Use the clutch fork to move the TOB toward the pressure plate.
While the TOB is against the pressure plate turn the flat head, while the flat head is sideways push the clutch fork so it makes the TOB slide away from the pressure plate.
well, thats all there is to it. I hope i helped some of you that havnt done an evo clutch yet.
-nick
-nick
Amen... I replaced the clutch as a jackstand warrior and this is a LOT harder through a little hole. This will help someone though or at least give them a good mental image of what has to be done if doing it from under the car.
Yeah thats what I used when I've done my two clutches. maybe it was just me though. But the throwout bearing release part was kinda harder to understand than this is. I guess because you can see what he's talking about more since the picture isnt taken from outside that little hole. But yeah...Those directions at evomoto got me through my first clutch job. VERY helpful also
