Inside Dash Fuse Panel
I didn't remove anything. Not sure if I have missing pieces down there or what. Looks like I would have to remove the entire part of the dash. maybe I need to look closer But I don't have a coin cubby down there. Not sure if the MR is different or what.
there should be a part next to the hood latch like this yours could be dif since this is the coin cubby your may be with the dimmer switch but on the side of that u should see the diagram and if you took the whole thing off it should be the one with spare fuses on the back
thats what it looks like if its a GSR... if u have a MR then u will have a knob in there and a wire and a couple of spare fuses and a small plastic fuse tool... but overall its the same thing... and in the same location...
however i wouldn't mind if someone post a pic of the diagram that goes along with the fuse box for the in-dash!!
just For a point of reference. Number 13(radio)is useless to tie into as can not put a fuse into that spot as there is a piece of plastic in the way. At least there is on mine and I have an 03.
What is fuse #23 for? Anyone know? Also, where is it?
Sorry, I know this is not on the correct thread probably. I just saw this picture on the thread and you were all talking about fuses, so I was hoping that someone might know which fuse I am looking for too or where I might be able to figure it out. Thanks
I am trying to figure out what fuse #23 is for. I'm having issues with my washer fluid pump/motor and I was wondering if this is a fuse for that because I can't seem to find one for it. Actually, I can't even find where this fuse #23 is on the vehicle. It says it is in the "upper." Any ideas where that is located?
I have a 2002 Mits Lancer OZ Rally. Thanks for any help
23 is for an intercooler sprayer in the evos that had it the oz won't have it
Pretty sure brake lights are in the external fuse box under the hood.
On a related note, what are 5 and 12? Never seen that symbol before.
I will be using some add-a-circuits for the constant and ignition power for my 3 defi gauges. So far, I know fuse 15 (door locks) and 18 (dome light) are constant-- I will be using my circuit tester to find one more.
