BR Underhood metal bushing install
This is a how to for installing the BR underhood metal shifter bushings.
They're cheap yet very high quality. The improvements in shifting make them all the worthwhile.
To install these you need:
10mm deep socket
Needle nose pliers (large and small)
Some patience and a little muscle.
Drop light
Little bit of grease or antisieze (optional)
For starters, put the ebrake on and leave the shifter in the neutral position. Pop your hood and walk over to the drivers side of the car.
Attachment 339493
The transmission linkages are located behind the battery.
Attachment 339494
Loosen the 2 10mm nuts that hold the battery clamp on and remove it. They just hook into the tray.
Then pop off the red battery terminal cover (it just clips in place) and loosen the 10mm nuts which old the terminals tight. Remove the battery and set somewhere out of the way and NOT on concrete!
Here's what you're going to see with the battery out.
Attachment 339495
If you take a peek down behind the battery tray this is what you'll see.
Attachment 339496
I circled the small linkage bushing.
The large one is right next to it.
Attachment 339497
10mm deep socket
Drop light
Attachment 339493
Attachment 339494
Attachment 339495
Attachment 339496
Attachment 339497
Grab your large and small needle nose pliers and remove the cotter pins which hold the bushing to the linkage. After your get the cotter pin off, there is also a washer that can be removed and discarded.
Attachment 339489
Don't fret if you loose these cotter pins and Bushur gives you spares (thanks guys!)
After the pins and washers are removed, you can pull them off the linkage like so.
Attachment 339490
Now for the fun part. The bushings will just push right out of the cable with a little bit of thumb muscle, but you can try pressing them out with the pliers or a screwdriver.
Here's the small one removed.
Attachment 339491
Here's the large one removed.
Attachment 339492
Attachment 339489
Attachment 339490
Attachment 339491
Attachment 339492
So here's what we got.
Attachment 339485
The C clips fit into the groove on one side of the bushing.
Attachment 339486
(optional) Put a little bit of grease or antisize into the clamp groove of the bushing to make the clips slide easier and a little bit on the linkage to they'll be easier to remove should you need to pull the tranny at a later date.
Order of installation:
Start with the large bushing first!
Set the bushing into the linkage shaft
Slide the cable over the bushing
Insert the C clap
Insert the new cotter pin
Here's what it'll look like installed.
Attachment 339487
Here's the small one installed.
Attachment 339488
Now, before you reinstall the battery, go have a seat in the car and try shifting the gears for a bit. If you installed everything correctly, shifting should be smooth and they won't pop out.
If you're happy with the improvements, check out the shifter base bushings BR sells too!
https://www.evolutionm.net/forums/ev...g-install.html
Attachment 339485
Attachment 339486
Insert the C clap
Attachment 339487
Attachment 339488
Great write up! This should be a sticky!
Quick question. I know most people have trouble getting the bushings loose from the linkage cables themselves, but I seem to have the opposite problem. The cables come off of the bushings no problem but i cant get the bushings off of the transmission linkage. They are like seized on and I have tried everything. Basically used an entire can of PB power blaster on it too..
Any suggestions?
thanks!
-Ethan
Any suggestions?
thanks!
-Ethan
Any suggestions?
thanks!
-Ethan
Any suggestions?
thanks!
-Ethan
Otherwise, you could try a vice grips and spinning it off.
http://www.carquest.com/partsBatteryFAQMyths.html#2
http://www.thebatteryterminal.com/Te...n_Concrete.htm
Simple install to say the least but before I bought these I did not know what they looked like or have never installed bushings before. Wish this was around when I originally did mine. But to be honest it was a breeze.
Any suggestions?
thanks!
-Ethan
Any suggestions?
thanks!
-Ethan
So I have looked around and this is a very newbie question but what exactly is the advantage of having a metal shifter linkage bushing vs. a rubber one?
Essentially, how does this linkage work and why is a metal bushing better?
I have both the shifter linkage bushings and shifter base bushings from Buschur (lots of B's) in my possession. I have already installed the base bushings. I plan to install the linkage bushings soon. But can anyone explain that?
I've tried searching on here and on Google and so far it just says that it improves my shifting feel and tightens things up/makes it more crisp/more "rifle-bolt" like...
