Window Belt Moulding Trim Removal/Install Help
Old Apr 26, 2014, 06:45 AM
Rrrr's Avatar
Hi guys!
As the title states I wanted to replace my worn out window belt line with new ones, but so far I just managed to do some scratches on the door during the process.
There's a guide on the latest lancer/evo x ( https://www.evolutionm.net/forums/09...ndow-trim.html ) but none on the CT9A.
Anyone? This will be a good guide on DIY painters as well.
Old Aug 2, 2015, 01:47 PM
qu1ckz's Avatar
Hello,
you need to remove the mirror first.
Afterwards you'll be able to pull the molding upwards.
With the molding pulled up, you can slide it one inch towards the rear and pull it out in upwards direction.
You can see the clip which is holds the molding near the mirror, in the below picture:
Kind regards,
qu1ckz
Ferp
Jul 20, 2017 02:48 PM
ct9asilver
Jun 24, 2016 03:33 PM
Tommyy
Jan 27, 2016 12:04 AM
velocityhead
26
Jun 2, 2015 06:36 AM
vtluu
15
Feb 7, 2008 09:40 PM
Quick Reply: Window Belt Moulding Trim Removal/Install Help
