location of oil pressure sensor?
Im looking for the exact location of the stock oil pressure sensor. not for gauges or anything, i have a flickering light and im changing the sensor out for a new one. if that doesnt work im going to replace the oil pump.
That is correct on an evo 8 but seeing the O/P has a Evo 9 that is incorrect,but thanks for playing. See my post above yours...
Well the manual is WRONG,and do you know why it is wrong? The oil feed for mivec gets its oil from that hole,which is larger and a banjo bolt screws into it.
Any more questions?
Any more questions?
BTW,that is the EXACT same page number as the EVO 8 service manual for 2003 as seen here. http://www.ne-evos.net/data/2003serv...0003900-12.pdfClick on the blue 12-4 in link provided.
Are you sure that is from the evo 9 manual?
