Where are the front JACK points on my EVO VIII
Im changing the oil in my car for the first time. I dont know where the jack points are on the front of the car. Also where should I put the stands?
Telltale signs
The evo on stands is an excellent specimen of a car that gets to play. Note the silver bottle of motul brake fluid. Probably the best stuff to put in your EVO brake"veins". Note the telltale "brown"bo front calipers which gracefully age with heavy braking. excellent examples of an EVO that gets to "play" the right way!
for oil change jack it from the front right on the lower engine brace...btw jacking the car from the side by the side skirts is a very bad idea cause you will start bending the thin metal, so i would not consider those jack points.
csmartz (Aug 21, 2019)
I have never seen those jack/stand points before. Thanks for sharing!
x2
I just checked the owners manual and I couldn't find anything on it.
Here's the locations the service manual tells you to use:
I've never used the locations that OTown used but from the looks of it he knows what he's talking about.
