How To: Engine/Turbo/Drivetrain
Here are How-To links specific to engine/turbo/drivetrain
Fuel Injector Installation
boost leak test
solid shifter base bushings
solid shifter base bushings (alternate)
solid under hood shifter bushings
solid shifter and under hood bushings (alternate) (text only)
magnus v5 intake mani - evo ix specific issues pointed out
bleeding lifters
o2 housing
o2 housing (alternate)
o2 housing (alternate) (text only)
release throwout bearing
br catch can/oil dipstick
perrin catch can
saikou michi dc3 catch can
rre catch can & pcv valve delete
weaponr catch can
mini oil trap
hks rs intake
hks rs intake (alternate) (text only)
modifying stock wastegate actuator
clutch install (text only)
05+ clutch install alternative
exhaust man (text only)
downpipe back exhaust
downpipe back exhaust (text only)
downpipe (text only)
test pipe (text only)
jun b.l cat back exhaust
dejon tools leak stop kit (mr bov)
diy plastic diverter valve screw mod
oil pressure and temperature sensors
clutch pedal adjustment
diy inexpensive catch can
nipple install on licp (helps eliminate boost flutter)
defi specific boost & oil pressure/temp gauges/sensors
universal o2 sensor splice in
windband o2 sensor
valve spring and retainers
walbro 255 lph fuel pump
walbro 255 lph fuel pump (alternate)
throttle body shaft seals
lower intercooler pipe
oil change
mechanical o2 fix
mechanical o2 fix (alternate)
weld cat heatshields around test pipe
oem hypergrounding kit
oem hypergrounding kit locations (video)
grounding kit
intercooler piping t-bolt clamp locations and sizes
serpentine belt removal
timing belt/balance shaft belt/accessory belt
timing belt
front motor mount
front motor mount (no press)
arc super induction box
manual boost controller (two line routing diagrams)
manual boost controller (alernate)
manual boost controller (alternate)
lightweight battery
lightweight battery (alternate)
broken downpipe/o2 housing bolt removal
compression test
battery relocation to trunk
battery relocation to trunk (alternate)
quaife front lsd
perrin o2 simulator
perrin o2 simulator (text only)
remove spark plugs (text only)
intercooler piping (text only)
remove injectors (text only)
three piece scatter shield
nology hotwire spark enhancer
aem cdi box
diy free flowing stock exhaust mod
boost gauge
boost gauge (text only)
clutch release cylinder push rod (text only)
clutch master cylinder
clutch line
electronic boost controller
apexi avc-r
apr head stud w/o cam removal (text only)
drivetrain fluid changing (good pictures)
drivetrain fluid filling w/ pump
drivetrain fluids change
transfer case removal (text only)
rear diff fluid change (text only)
rear diff removal (text only)
oem style intake filter (text only)
hks eids
perrin short shifter
b&m short shifter
kartboy short shifter
egr removal including evap/charcoal canister
make a boost leak tester
accusump
cleaning throttle body (text only)
twin/triple clutch conversion
boost leak test
bleeding lifters
o2 housing
perrin catch can
weaponr catch can
mini oil trap
hks rs intake
windband o2 sensor
oil change
mechanical o2 fix
grounding kit
timing belt
front motor mount
lightweight battery
compression test
quaife front lsd
perrin o2 simulator
aem cdi box
boost gauge
clutch line
apexi avc-r
hks eids
b&m short shifter
accusump
jpmcleod (Jan 30, 2024)
