How to: Make your own undertray (cheap & easy)
After driving with no undertray for about 3 years I finally decided I NEED one. The stock one is a piece of crap...i find the whole multi-piece design is more inconvenient than anything, and having to use like 25 of those hard to find/expensive plastic clips doesnt help either. There are some high-quality replacements out there, from buschur or beatrush for example, that arent too expensive, but to ship them is like $150+, which isnt anyones fault, thats just the way it is. I was quoted no less than 300 shipped (around $350 to NY) from the vendors i asked. The undertray isnt absolutely essential, but my engine bay/underside of the engine is always filthy, and no undertray does mess with aero, which track guys will attest to. If i were a track junky i would probably go with a legit piece from one of the above companies, but $300+ for something thats not visible, only gets dirty and scuffed up, and isnt really required for daily driving is too much. Plus, whenever I looked at the aftermarket undertrays, I would say "that doesnt look that hard to make." So let's give it try:
Before I start, I want to say to anyone willing to try this, its not that hard. I'm no mechanic or craftsman...I'm in the process of getting my doctorate in pharmacy, so im more of a nerd than anything. I do all the work on my cars and have had numerous manual labor/maintenance type jobs so i know how to work with my hands. The only tools you will need are: a pencil, straightedge and tape measure for measurements, a cutting tool (i used a dremel), a drill and some basic hardware and tools for mounting.
-The hardest part was figuring the dimensions for this thing. I just jacked up the car and took some rough measurements. Also, finding a good plastic rivet to use was hard. most of them suck, I luckily have a privatly owned auto parts store near me that has a great selection. oem fasteners are great too but i was quoted $1.62 a piece. BS
-Budget is key. If you spend too much it defeats the purpose of this project. I kid you not, I spent less than $40 on this project. $25 for the material, and $10-15 for mounting hardware.
Here's what i used: This is a $25 piece of 4' x 8' FRP wall panel from home depot or lowe's. I questioned whether it would be tough/heat resistant enough, but its held up fine so far.
Made some rough measurements, did some cutting...By the way, I am more than willing to share my dimensions for this thing. The only measuring i did was for the portion you see below. everything else was eyeballed or traced.
Next, I took off the front bumper and used the lip as a template to trace out and cut for the curved shape of the bumper. then i just lined up the holes on the lip with the piece and drilled them out.
It actually lined up and mounted great.
Planning ahead, I drilled some holes next to the holes on the interior of the bumper so i could stick an allen wrench or something in there to hold the undertray down when fastening clips
Got some u-bolts from lowe's, 80cents a piece. I'm going to use these to attach the rear of the undertray to the forward underbrace. Use some plastic rivets to attach the front to your lip...your drill bit size for the holes should obviously match these rivets, or close to it at least.
Its awkward maneuvering this thing up in here but i got it on. I had to trim some away for my licp and its clamp to the ic. its just a tiny amount and will be different for everybody. I use ETS ic parts, but im sure it will be similar for others. You also have the downpipe which comes close as we will see in a moment..
As you can see i have cut a portion so i will not have to remove the panel to access the jack point here. My measuring for this was extremely crude so i wont even discuss the details. You'll figure it out...and it doesnt have to be perfect, or nearly as large as mine for that matter.
Here is a shot from the rear. you can see how i have attached the u-bolts to the bar. I just peeked up at the underbrace as i was mounting the undertray and marked on the opposite side where I would drill the hole. then i measured for the other hole. there is a bracket that goes across the bolt to fasten it so the holes dont have to be perfect.
Trimmed some of the rear away to neaten things up. UPDATE...after driving around for a while, I ended up snagging one of these u-bolts on something. the fix: install them inverted to what you see here. Its a little more troublesome to sqeeze ur hands in to get the nuts on, but much safer. u could also trim the threds down more than i have here. I also doubled up the material for mouting hole to make them more sturdy. Just epoxied a piece of leftover panel across the bottom 6" or so.
A better look at the u-bolt from the top
And here's the car
As you can see I did the prep for this project in my small apartment, cutting and trimming out on the doorstep, and installed it in the parking garage...so anyone can do this.
I don't drive the evo in winter, but i have let it run numerous times, and went for a quick 15min drive down the road the other day. no signs of heat damage. I bought a small sheet of aluminum, 6" x 18" at lowe's also for about $10, to use as a heat shield in case the dp starts melting the panel. So beware here, because i have not tested this under hard driving...this thing may melt away the first time i drive hard. there is a good inch to 1.5" between the dp and the undertray...this is the reason there is no fastener in the center of the undertray, to allow this space. It is securely fastened to the car and there is no rattling or other noise while driving.
I'm on the forum quite often so ill be available to answer questions..although i spent way too much time on this write up so it should be good. If the thread shows significant interest ill post up some dimensions. However, I don't know how popular the 'how to' section is...enjoy
EDIT: Due to some requests, here is a diagram for dimensions...keep in mind this is for an VIII bumper with an aftermarket do-luck style cf lip. that 62" across the top may not fit quite right for you, so you may want to double check with your exact bumper & lip setup...also, some of the 18" at the bottom got trimmed off. these dimensions will get you a rough shape, you will be responsible for trimming it according to your individual setup...i did alot of trimming with the tray on the car for better accuracy
And here's the car
The following 2 users liked this post by YogSaahoth:
bradsayz (Nov 22, 2022),
SalvagedEvo7 (Jan 26, 2023)
Good Write Up
Considered laying down some fiberglass on this to strengthen it? It seems like a very flexible piece. You could probably make a nice splitter using this stuff also, as long as you reinforced it properly
Another consideration would be putting some 90 degree angle aluminum riveted in front of the tires to divert some air. I might make a trip to lowes tonight and see what this material is like
Great write up. I've been in the same dilema not wanting to spend $400 for a piece of alum/plastic... and as you said the stock unit is enough to make you drink. This is a great idea and seems you took your time and did it nicely. I'd be curious to see if the heat effects it at all. Either way keep us updated as you start to put some miles on it.
thanks for replies...i wondered if it would be too flimsy also. i even considered doubling the material up with a 2nd panel and just jb weld them together or something. it seems to be pretty firm the way it is tho...had it up to 50-55mph the one day and held together nicely..its as light as a feather the way it is also
let me put together a diagram or something with the dimensions...it seems like people may find this useful
I'm going to make one, but taking it another step. I'm not looking to just make a smooth undertray but brake cooler guides, complete flat bottom, functional splitter, and I'm not going to mount it to the bumper, its going on custom brackets fabricated to the bottom radiator support.
Don't get me wrong I like your design, you did a good job working with what you had, I'm just building mine for a custom bumper/canard setup in a race application. I require slightly different things
