Wiring diagram for Lancer and EVO VIII
Wiring diagram for Lancer and EVO VIII(look inside)
Enjoy, use it wisely . (Mods might want to make it a sticky).......
wire / color / polarity / location....
12volts white + ignition harness
Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Accessory blue/black + ignition harness
Second Accessory blue/white + ignition harness
Notes: Not required for remote start.
Keysense blue ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock purple - driver kick, door harness
Power Unlock lt. green - driver kick, door harness
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights+ grn/yel (L), grn/wht (R) + wht plug bottom of fuse box
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - wht plug bottom of fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin green/orange - light in trunk
Factory Alarm Arm N/A
Factory Alarm Disarm gray - driver kick, door harness
Tachometer black/yellow or black/green ac either ignition coil
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger blue/red or red - steering column
Notes: It is blue/red on the standard models and red on the Evolution VIII models.
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: DEI 555U (requires a programed key for remotestart)
Notes: Only the Evolution VIII models have the immobilizer.
And here is a diagram for use of a Turbo timer w/ aftermarket alarm. Enjoy....... And if you guys need any help email, aim, pm me for help on the info i have provided for you....
johnjonfenomeno
177
Aug 23, 2020 08:45 PM
Sr20kidD
20
Aug 18, 2011 09:53 PM
rhitme03
Jun 6, 2011 01:50 PM
ApexSilver06MR
44
Dec 21, 2009 08:43 AM
freedom
28
Dec 2, 2006 04:52 PM
