How to keep the cuppler into the throttle body without poplin off
I need help on how to keep the cuppler from poppin off replaced the hose clamp 3times feels tight but after a pull shoots out idk wat to do pls help this is giving me a headache limpin it home 95percent of the times I had it fine b4 the. I change my upper icp an idk wat happen it jus doesn't want to stay on that throttle lip pls help Asap btw wat does hairspray do? I keep hearing use hairspray on it but don't user stand how
You need to use T-bolt clamps. Regular clamps arent going to hold. The hairspray is simply spray it on and then clamp the boot on and when the hairspray becomes tacky it dries and basically glues the boot on.
which UICP do you have? is it aftermarket? if you're still with the stock one, i imagine its prolly all worn out from all that popping, reinstallation, hairspray etc. if its aftermarket, idk whats up.
i had the problem before. i used the right t bolt clamp on the stock hose and my sisters hairspray. it still blew off. then i went with ETS stock route UICP with the included hoses and clamps and the problem went away....
