Vortex generator help (what to use)
Old Apr 25, 2014, 03:34 PM
wowzers's Avatar
Originally Posted by mrxx
Waiting on mine to arrive as well can anyone shed some light on install at all
"geeday maite, crikey!"
You will have to pull the weather strips up, starting from the boot.
then stick it on, the Antenna should hold it on also.
Old Apr 25, 2014, 09:08 PM
DRO.Evo8's Avatar
3m tape works awesome you just have to prep the surface properly before applying to the car.
Old Apr 26, 2014, 05:38 AM
EVOVIIImadrid's Avatar
The Search button is your friend
https://www.evolutionm.net/forums/showthread.php?t=470227
Old Apr 26, 2014, 07:40 PM
wowzers's Avatar
Originally Posted by EVOVIIImadrid
i hate search
Old Jun 15, 2014, 09:57 PM
Presidential18's Avatar
If you clean the surface real well and put 3m on the VG then 3m along the parts that the VG it lie on , it wont come off at all
Old Jun 25, 2014, 09:25 PM
mini_moose's Avatar
if my roof is sprayed with plasti dip, would it still hold?
Old Jun 26, 2014, 06:25 AM
No it won't you need a clean surface. Just clean a strip for it then recoat it.
You should always have a clean surface for a proper bond.
Old Jun 27, 2014, 07:42 PM
mini_moose's Avatar
Thanks! gonna do this tonight
Old Jul 1, 2014, 07:30 PM
Smelli Bugatti's Avatar
Nice find with that SIKAFLEX, Thanks. The Evo X version needs some help at the tips. The tape just isn't getting the job done at an Evo level
Old Jul 1, 2014, 07:39 PM
500+'s Avatar
I got mine from rexpeed and the tape that us supplied is quite strong... Does it's job.
Old Jul 24, 2015, 05:23 PM
day day's Avatar
3m heavy duty. Its still doing the job for me.
Old Jan 5, 2016, 01:42 AM
I_want_MR's Avatar
Originally Posted by grim~
i used loctite red double sided tape,you'll never be able to take it off one you put it on with that stuff.
Never heard of this stuff.
Never seen it. Where would it be other than online?
Old Jan 24, 2016, 10:42 AM
crazyprac's Avatar
So I took the advice on using one of those 3m red heavy duty double sided tape, cheaper than the "auto" one but looks exactly the same, I had it on for a year but I notice one side is lifting up just a little. I took a hair dryer and did a few passes and firmly pressed. It's back to perfect! But I did use alot of tape... Basically all along both sides of the vortex. I saw some diy that uses just a little but better safe than sorry.
Old Nov 7, 2016, 05:06 AM
C_ST_718's Avatar
Speaking of...anyone know where they sell them for a good price?
I wouldn't mind having a graphite one.
Old May 15, 2017, 03:09 PM
A12DY B's Avatar
windscreen sealant is very strong obviously
however not so easy if you want to remove
Graphic
Sep 20, 2017 02:45 PM
kwpilot
May 14, 2017 03:34 PM
detroit pistins
Mar 9, 2017 06:43 AM
kyoo
Mar 8, 2016 06:32 PM
mda56
Mar 1, 2016 01:02 PM
Quick Reply: Vortex generator help (what to use)
