DIY Engine Dress-Up Bolt Kit on a Budget
Just did mine today. Thanks for the awesome write up. My only complaint was that all of the #6689 bolts were far longer than needed. If i were to do it again i would order 20mm long bolts. Also i wish i would have gotten two larger bolts and washers to replace the 14mm bolts on the center of the upper strut bar.
Yea, the strut bar I was a bit weary about and I didn't bother with it.
The 25mm bolts are definitely plenty long for most of the application, but since they're not in danger of rubbing on anything underneath I didn't worry about shortening them up. I believe all of the 25mm bolts would be fine with 20mm bolts in their place
I did, it's on the first page
adding a bunch of part numbers to a shopping cart doesn't require much effort, and it's not worth my time to order these, keep them on stock, and then pay shipping to get them to people (nor do I want to do that unless I'm getting at least 2x mark-up, in which case no one would order from me anyways)
very true
I recently picked up one of these kits with aluminum washers and the quality is pretty good:
http://www.ebay.com/itm/BLUE-20-PC-BILLET-ALUMINUM-FENDER-BUMPER-WASHER-BOLT-ENGINE-BAY-DRESS-UP-KIT-E-/190808094463?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6d0c76ff&vxp=mtr
Oh nice - those are pretty good looking
yea, i'd love to find just finishing washers that are like that, but i haven't been able to (and haven't really looked) yet. the ones from bolt depot work fine, but I like the more "robust" look and the squared-off look of something like that sickspeed/pwjdm kit
I suggest you refrain from replacing any grounding bolts. SS does not have the same conductivity and will cause issues. I have torn apart fully tucked show car with starting issues, only to find out that he replaced the bolts with SS at whatever show.
I thought I had a good before pic but I guess not. Here is the updated pic with the DIY bolts. Not all are in yet. I changed over the more appearing ones. I missed liked 4-6 that I'd like changed out.
I wish I kept some of the washers stainless instead of switching them to blue! I guess I'll have to pass by ACE!
