DIY Engine Dress-Up Bolt Kit on a Budget
All parts are from BoltDepot.
BoltDepot currently does not ship outside the USA. If you are in Canada, Allens Fasteners ships to Canada, but you can order these bolts from any online retailer. I won't be doing the legwork to find part numbers there but bolt size, thread spacing, and bolt length are included on all of the information I posted below. You can order bolts from anywhere you please, all you need are the measurements!
I would recommend high-temperature anti-sieze of some sort. I used stuff rated to 1500* from NAPA
Fenders:
Small Flat-Head Tapered Bolts (6mm x 1mm):
Headlights:
Radiator Tank
Front Bumper
Fuse Box
ACD Tank
Large Flat-Head Tapered Bolts (8mm x 1.25mm):
Radiator Bracket
Radiator Fan
Power Steering Tank
Power Steering Line
A/C Line
Timing Belt Cover
Small Socket-Cap Bolts (6mm x 1mm):
Valve Cover
Spark Plug Cover
Top of Engine & Boost Controller Mount
Radiator Hose
If you want your engine bay to look exactly like the pictures above, here are the exact item numbers and quantities you need to order:
Total:
Grand Total: $16.72 + Shipping
(as of writing this)
I would order extras of stuff. It's dirt cheap and if you end up having to pay shipping again you will kick yourself (shipping is was $10 on my first $25 order and was $10 on my most recent $5 order). Order extras now and just have them on hand if you need them! There are many other bolts in the engine bay that you can replace, these are just the "main" ones that I did
Things I would order extras of (maybe 10 each? they cost next-to-nothing anyhow)
Special Features:
THIS KIT WILL NOT REPLACE:
Fenders:
Qty. | Size | Location | ID |
6 | 16mm | Fenders | #6687 |
6 | #14 | Finishing Washers | #2941 |
Headlights:
4 | 20mm | Headlights | #6688 |
4 | #14 | Finishing Washers | #2941 |
Radiator Tank
2 | 20mm | Radiator Tank | #6688 |
2 | #14 | Finishing Washers | #2941 |
Front Bumper
2 | 16mm | Front Bumper | #6687 |
Fuse Box
2 | 16mm | Fuse Box | #6687 |
ACD Tank
2 | 25mm | ACD Tank | #6700 |
2 | 5/16" | Finishing Washers | #5579 |
Radiator Bracket
2 | 20mm | Radiator Bracket | #6699 |
Radiator Fan
2 | 25mm | Radiator Fan | #6700 |
Power Steering Tank
2 | 25mm | Power Steering Tank | #6700 |
Power Steering Line
1 | 25mm | Power Steering Line | #6700 |
1 | 5/16" | Finishing Washers | #5579 |
A/C Line
1 | 25mm | A/C Line | #6700 |
Timing Belt Cover
3 | 20mm | Timing Cover | #6419 |
3 | 6mm | Flat Washers | #4516 |
Valve Cover
6 | 25mm | Valve Cover | #6420 |
6 | 6mm | Flat Washers | #4516 |
Spark Plug Cover
4 | 12mm | Spark Plug Cover | #6417 |
4 | 6mm | Flat Washers | #4516 |
2 | 14mm | Top of Engine | #14996 |
1 | 12mm | My Boost Controller | #6417 |
Radiator Hose
2 | 12mm | Radiator Hose | #6417 |
2 | 6mm | Flat Washers | #4516 |
6 | 16mm | Fenders (Both Sides) | #6687 |
2 | 16mm | Fusebox | #6687 |
16 | #14 | Finishing Washers | #2941 |
2 | 20mm | Radiator | #6699 |
2 | 25mm | P/S Tank | #6700 |
1 | 25mm | P/S Line | #6700 |
2 | 25mm | Radiator Fan) | #6700 |
10 | 5/16" | Finishing Washers | #5579 |
18 | 6mm | Flat Washers | #4516 |
Total:
Qty. | ID |
6x | #6688 |
10x | #6687 |
16x | #2941 |
8x | #6700 |
2x | #6699 |
10x | #5579 |
6x | #6420 |
2x | #14996 |
7x | #6417 |
3x | #6419 |
18x | #4516 |
Qty. | ID |
4x | #6688 |
6x | #6687 |
10x | #2941 |
4x | #6700 |
2x | #6699 |
6x | #5579 |
6x | #6420 |
6x | #14996 |
4x | #6417 |
16x | #4516 |
Special Features:
- If you wish to change the color of the bolts (I wouldn't recommend as the paint will be stripped / scraped off where the allen wrench sits) or the finishing washers / washers (these are the only things I'd paint), DupliColor MetalCast works great for that. G35 Driver did a good write-up on coloring with the DupliColor MetalCast
- You can replace any of the 6 valve cover bolts with the #6689 bolts and #14 finishing washers if you prefer that look
- [b]You should specify that you DO NOT WANT knurled bolts if you order the socket caps bolts listed for the valve cover / timing belt cover / etc. Knurled bolts have a texture around the head where-as smooth do not. If BoltDepot does not have smooth cap bolts in stock they will call you and discuss your options with you. This isn't mandatory, but smooth cap look much more professional and cleaner than knurled
- The four bolts on the top of the front bumper (I'm missing some hardware so there's nothing to screw them into. You could also buy some #4776 or #4795 nuts to screw the 4 bolts into that you'd put there
- Grounding bolt just below the front of the fusebox. I'm not an electrician so i didn't replace this but I'm assuming there's no issue using a stainless steel bolt for this? I have extras that I'm going to replace it with later
- The two bolts holding the larger fan on the engine-bay side of the radiator. These bolts are threaded like wood screws and I'm guessing they screw directly into the plastic as opposed to being truly threaded
- Any of the bolts on the right side of the engine by the valve cover (cam angle sensor and whatever the hell else is over there)
- The bolt holding the throttle cable on the front of the valve cover (#6417) is recommended for that
The following 2 users liked this post by llDemonll:
evo8tanner (Feb 2, 2017),
Roadrunr (Nov 24, 2020)
The website above doesn't ship international...
for Canada owners, I searched a lot and I think the best/cheapest choice is Ebay for the same socket head bolts.
edit: Also: http://www.allensfasteners.com
Since this is an informative thread. Please add this information:
If you would like to add a little spruce of color, recommendation: Duplicolor MetalCast
Review: additional info
Nice write-up. I will be doing this shortly!
did a little searching as well and ebay does look like the cheapest method
