Walbro 450 lph e85 fuel pump diy evo 8/9
I have done several of these installs and i have yet to get the pump hanger to fully seat without denting the bottom of the tank... All evo 9s my first 8 will be in a few weeks...
As for the guy claiming they fail... I pretty sure he was running non ethanol pumps. I beta'd this pump for walbro and i'm on my first pump for over a year... None of the cars i've done installs on have had issues... And i dd my car with 596whp... My fuel pressure at idle is actually to high at 56psi because the flow rate of this pump hard wired. Dual voltage cars dont seem to have that issue. Anyway... I love this pump and cant see why people run double pumper setups anymore...
Also, I'm successfully running the big sock that comes with the pump. Basically, a bit more trimming of the pump and housing is needed. No dent in the bottom of the tank, but the bottom of the sock does rest on the bottom of the tank. No issues with fuel flow through the sock because the sock is designed to keep the opening to the pump inlet from collapsing.
sumopower87 (Mar 6, 2022)
I run the sock that came with it as well... Every install i have done i have double checked and the seal with be about 1/8 an inch from being fully seated on the tank... I dont like banging metal together in a rising fuel vapor if i dont need to... You should know me better then that by now fred...
2 which is what you probably did I'd trimmed the housing and the barb alittle more so that the pump could slide higher up.
As far as the sock, I have it in my hands right now and one thing you'll notice is that unlike the oem, or aeromotive sock is that the metal washer is not detachable from the pump. Therefore there's the extra plastic piece on the bottom so you can press it on.
After looking at it I just did not feel comfortable using it. I will be pulling it on my next oil change to put a metal worm gear clamp on it. So I may try the sock again.
Also note that the bigger sock was fully flush with the pump, that's why I trimmed the bottom retainer so much.
