DIY: a/c clutch
DIY: a/c clutch
This thread is for people who has a/c clutch problem.
Recently my Evo was blowing hot air when i turn the a/c on. It didn't happen to me when i last used it back in summer 2012. It been getting warmer and we all need our a/c. I took the car to the shop to have them check for leaks. they told me the levels was unstable and they vaccum everything out and refilled it. I drove it for 15min with the a/c on nice and cold then out of the blue hot air was blowing. Took it back to the shop and the tech guy told me the clutch wasn't engaing. They qutoed me at 1500 to replace my whole a/c system cause you can't just replace the a/c compressor, you have to get a brand new dryer and some other stuff. I didn't have 1500bucks to blow, so i hopped on EvolutionM and search for a/c clutch. I came to this thread https://www.evolutionm.net/forums/ev...ng-advice.html and was really helpful and tons of information. So i took some picture and hopefully this thread i created will help other members on here. This is my contribution to EvoM.
The link above talks about changing out the shims and coil, I opted to change the coil and armature and shim since i was already at it and figure if I'm gonna get dirty then i'm gonna make sure i get dirty all the way. The Tap trick worked for me, meaning if i hit the a/c clutch with something it would blow cold air but evenutally after driving for a couple of min, the clutch won't spin again. I checked my gap on my a/c clutch and it was at .035 inch that is super way off.
All parts are Oem and i will include the part number i order.
Parts list:
MR568462 hvac, air conditioner & heater, condenser, compressor & lines, coil $64.93
MR568461 hvac, air conditioner, compressor, clutch plate & hub assy Lancer w/Turbo $101.01
MR315936 hvac, air conditioner & heater, condenser, compressor & lines, repair kit 1 $20.73
Special tool needed: snap ring pliers and feeler gauge
Step: 1. Jack the passanger side off.
2. Remove the passenger side wheel
3. Remove the 3 12mm bolt oil cooler bracket and place the oil cooler on the ground and not in the way.
4. remove the sepretine belt http://www.joe250.com/cars/evo8/belt...ltremoval.html
5. Remove the 14mm nut on the a/c clutch. I used a cordless impact wrench
6. wiggle the armature out
7. remove the shim
8. remove the snap ring
9. remove rotor. I had to bang it out to get the rotor off
10. remove the second snap ring
11. remove coil. be sure to unplug all connector
To install is just the reverse order. Don't forget to check your gap with your feeler gauge. Any question feel free to post them or you can Pm. Enjoy your a/c and Thank you EvolutionM.
Some quick notes: In the service kit Mr315936 i used the second to smallest shim, that shim put me at .015 inch for gap.
Parts list:
7. remove the shim
The following 4 users liked this post by CharliEvo8:
Thanks, I'm sure people will find this information useful.
It just depend if the a/c clutch is really your problem. Before i fixed my clutch, i would press my a/c button my clutch wouldn't engage. My fan would work, everything else seem to work when i press my a/c button except the compressor which turn out to be the clutch, when check for gap it was way off. I wasn't in the mood to pull the compressor off and drain the a/c and take it back to the shop to get it refill and check for leaks. Lucky it was just the a/c clutch.
See the attached image.
https://drive.google.com/file/d/0B0c...ew?usp=sharing note the fuse on the right side of the pic is burned looking
