starter motor location
Its on the front bottom of the engine... Beside the turbo... Depending on how modified your car is it should be easy... 2 14mm bolts one on the tranny side one on the engine side... Then the 12mm nut for the battery cable and the clip for the signal wire and it comes right out.
Only because im in the process of replacing trans and tcase, step # 13!
http://www.evomoto.com/tech_info.php...2b08b02bb2c96e
To OP it literally takes 10 minutes to remove and replace one. There's a bolt on either side of the starter and then there's a signal wire clip and a power wire.
I cannot find mine even with this help. I have removed the undertray but cannot see the shield for the starter anywhere. From the front is it before or after front axle, right or left? Are there any other covers or parts i need to remove to make it visible?
On almost any vehicle, the starter engages the flywheel or flex plate. The flywheel or flex plate lives right behind the engine in the front portion of the bell housing. Follow the engine/bell housing seam around and you will encounter the starter.
Ted B
Dec 19, 2023 08:35 AM
FS[Northeast]: NY: OEM Starter Motor - 150$
MisUnderStood
Nov 24, 2017 01:39 PM
WTB[Canadian]: Evo 9 Turbo and Evo 8/9 Starter
Ferp
May 18, 2017 03:45 PM
nor11384
Feb 20, 2016 05:06 PM
