AEM Turbosmart Innovate etc. Wideband Kits, Gauges, and EBC At Mellon Racing
Old Jul 11, 2011, 11:35 AM
Mellon Racing's Avatar
These products are only a few of the many we have at our website... Check us out at: http://www.mellonracing.com/
AEM UEGO 6-in-1 WB02 Gauge Kit
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features Include:
*Bosch sensor included!
*24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda
*Integrated three-digit display reveals AFR or Lambda in real time User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
*Ideal AFR monitoring tool for carbureted applications and engine dynamometers
*Does not oscillate AFR like narrow band sensors
*Serial data stream included for output of AFR (RS 232)
*Accurate to 0.1 AFR
You can check this product out and get additional information at: http://www.mellonracing.com/index.php?main_page=product_info&cPath=1_28&produc ts_id=612
__________________________________________________ _______________
Innovate Motorsports LC-1 WB02 kit + Gauge
Hey guys Mellon Racing has the Innovate Motorsports LC-1 WB02 kit + Gauge on sale. These come in either Red or Blue gauge and are compatible with Evoscan for logging when you purchase separately the USB to Serial converter cable.
This is the same WB02 kit we run in the Mellon Tuning 700+awhp stock ecu/mas beast.
You can check this product out at: http://www.mellonracing.com/index.ph...dc825937c61040
__________________________________________________ __________________
Turbosmart Eboost 2 Electronic Boost Controllers
NEW – Boost On Demand feature allows the user to select a boost group for a preset amount of time.
An instant overtaking power at a touch of a button!
NEW – redesigned User Interface helps in navigating through the menus.
NEW – bezel and face design featuring larger, easier to use function buttons.
PLUS…
• Factory Preset Mode provides beginners with an easy start-up option.
• Advanced User Mode unlocks up to 6 alternate boost mapping functions.
Presets for FWD, RWD, AWD, Bike and Drag racing needs.
• Gear-based Boost Mapping lets you set a different boost for each gear!
• Adjustable Boost Levels can also be mapped against TIME or RPM.
• Fully programmable auxilary output controls water spray, methanol or nitrous injection
• RPM Compensation Feature eliminates boost drop-off at high RPM
• Peak Hold/Max Boost Recall function monitors boost and RPM.
• Programmable Display can be configured to KPA, Bar or PSI
• Gate Pressure function eliminates wastegate creep
• Accurate Display to within +/-0.5% of full scale making it an ideal Boost Gauge!
• Programmable, audible warning alarm
• Integrated input for optional shift/warning lights
__________________________________________________ ____________________
AEM No-Weld O2 Sensor Mount 2",2.5",3",3.5" EVO 7/8/9/10
WHY YOU WANT ONE
If you need to mount an O2 sensor and don't know how to weld or can't find someone who can, this is a permanent solution that replaces a weled in O2 bung. Now simply drilling a hole in the exhaust is all you need to do in order to add a wideband to your car!
*Default 3 inch mount*
WHAT IT DOES
3" AEM No-Weld O2 Sensor Mount - Our No-Weld O2 Sensor Mount enables users to mount an O2 sensor without having to weld a sensor bung onto the exhaust. Simply drill a hole in the exhaust, install the gasket, and bolt the clamp. It's that easy! The 3" mount will fit exhausts from 2.75" to 3" in diameter.
*2 Inch Mount*
WHAT IT DOES
2" AEM No-Weld O2 Sensor Mount - Our No-Weld O2 Sensor Mount enables users to mount an O2 sensor without having to weld a sensor bung onto the exhaust. Simply drill a hole in the exhaust, install the gasket, and bolt the clamp. It's that easy! The 2" mount will fit exhausts from 1.75" to 2" in diameter.
*2.5 Inch Mount*
WHAT IT DOES
2 1/2" AEM No-Weld O2 Sensor Mount - Our No-Weld O2 Sensor Mount enables users to mount an O2 sensor without having to weld a sensor bung onto the exhaust. Simply drill a hole in the exhaust, install the gasket, and bolt the clamp. It's that easy! The 2 1/2" mount will fit exhausts from 2.25" to 2.5" in diameter.
*3.5 Inch Mount*
WHAT IT DOES
3 1/2" AEM No-Weld O2 Sensor Mount - Our No-Weld O2 Sensor Mount enables users to mount an O2 sensor without having to weld a sensor bung onto the exhaust. Simply drill a hole in the exhaust, install the gasket, and bolt the clamp. It's that easy! The 2" mount will fit exhausts from 3.25" to 3.5" in diameter.
You can check this product out and get additional information at: http://www.mellonracing.com/index.ph...0c97272a3173fb
AEM Analog Wideband Gauge EVO 7/8/9
AEM’s wideband air/fuel gauge unites unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM wideband also offers a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
Why You Want One
The system features a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. The backlighting is user adjustable to 7 colors, (white, blue, green, red, orange, light blue, and aqua), allowing users to easily match the wideband gauge to most factory gauge clusters.
*Accurate to .1 AFR
*Adjustable backlighting via a dial on the back of the gauge
*Two status lights for error detection and operating status
*Includes both white and black gauge faces
*Includes black and silver interchangeable bezels
*320 degree viewing area for unsurpassed resolution
*Includes Bosch sensor for optimum accuracy and reliability
*0-5v analog output included for use with data loggers and virtually any engine management system
AEM TRU-BOOST Gauge Type Controller EVO 7/8/9
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
*No external interface required for programming!.
*Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings.
*Quick connect technology eases the installation process.
*Two user selectable boost settings with peak boost memory.
*Scramble boost setting allows user to momentarily change boost levels.
*User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost.
*User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display.
*One (1) low-side output included for warning lights.
Auto Meter Dual Gauge Pod EVO 8/9
Auto Meter Gauge Pods fit well and look excellent when installed. Pods are available in black only.
You can check this product out and get additional information at:http://www.mellonracing.com/index.ph...847c2148ebd67a
Autometer Single Pillar Gauge Pod 52mmEVO 8/9
Autometer single pillar gauge pod. Fits Mitsubishi Evo 8/9
GlowShift Black 7 Color 60 PSI Boost Gauge EVO 7/8/9
Gauge Series Features:
• Black face gauge with magnified clear lens
• Black trim ring with black housing
• Red illuminated needle with full sweep
• Electronic Gauges has Opening Sweep Movement
• 7 color LED illumination number glow and color recall technology
(Gauge will return to previous color when vehicle is turned off)
• Fast and slow automatic color changing modes
• Gauge visor
• Mounting and Installation hardware
• Instructions
• 2 1/16th inch gauge or 52 mm diameter
Boost / Vacuum Gauge Includes:
• T-Fitting and Hose Kit
• All mounting hardware
• Gauge Visor
• Detailed installation instructions
• Reads: -30 Vac to 30 PSI
• Mechanical Gauge
• Free Tech Support
• 12 month limited warranty
This Boost Gauge is perfect for any turbocharger, supercharger, and is perfect for cars with a stock turbo; they can replace the inaccurate gauges that are in your car. This gauge is perfect for cars with an upgraded turbo and you can to rely on this accurate gauge. It can read up to 30 PSI and is sufficient for almost all applications including race and drag. These gauges are perfect for those who run a manual boost controller. With just a quick glance, you are able to read the various changes you have made. Severe engine damage is often the result with an improper boost gauge. When you increase boost without properly monitoring the levels of boost, you will often run into trouble. We recommend that you use our Air / Fuel Gauge to monitor the fuel system, so you do not run into any internal problems with the engine.
Autometer Triple Gauge Lower HVAC Cubby Pod EVO 7/8/9
The Evo Lower Console Pod is an excellent way of holding three 52mm gauges in style. Gauges are angled up and towards the driver for easy viewing. This pod goes over the cubby area below your HVAC/radio controls.
Zeitronix Ethanol Content Analyzer ECA EVO 7/8/9
The Zeitronix Ethanol Content Analyzer display provides real time readouts of fuel ethanol content and fuel temperature. The Zeitronix ECA features a slim aluminum case and blue LEDs to create a bright, easy to read, surface mountable display. Two analog outputs, ethanol percentage and fuel temperature, are provided for datalogging and engine management system use. A flex fuel sensor (GM part number 12568450 or 12570260) is required. Production vehicles including ones with the flex fuel insignia or which can run on E85 have flex fuel sensors. The sensor can also be purchased separately at GM dealerships and installs as part of the fuel line. The Zeitronix ECA connects via one wire to the sensor providing a real-time look at fuel mixture being sent to the engine.
Specifications
Displays fuel ethanol content from 0% to 100%
Displays fuel temperature in Fahrenheit and Celsius ranging from -40 to 125 F (-40 to 52 Celsius)
Two analog outputs: Ethanol % and Fuel Temperature for use with logging or engine management systems
Sleek aluminum enclosure with bright LED display visible even in direct sunlight
Compatible with standard OEM sensors used in most flex fuel vehicles (GM part number 12568450 or 12570260)
Dimensions: 2.8 x 1.8 x 0.75 inches (71 x 46 x 19 mm)
Made in the USA!
The ECA is available alone or as a complete kit, which includes the ECA, Flex Fuel sensor and sensor harness with connector.
GlowShift Black 7 Color Transmission Temperature Gauge EVO 7/8/9
• Gauge visor
• Instructions
Transmission Temperature Gauge Includes:
• 1/8 NPT Electrical Sender Unit
• Gauge Visor
• Reads: 120 to 300 F
• Electrical Gauge
• Free Tech Support
This Transmission Temperature gauge displays the temperature of the transmission fluid and reads between 100 and 300 degrees Fahrenheit. This gauge is very important for anyone who is carrying heavy loads or towing trailers. This gauge can warn you of any problems before costly repairs occur. The sending unit can be mounted directly into the transmission pan. Note: If you have a drain plug in your transmission pan with a 1/8npt fitting, sending unit will work there.
GlowShift Black 7 Color Oil Pressure Gauge EVO 7/8/9
• Gauge visor
• Instructions
Oil Pressure Gauge Includes:
• Detailed Installation Instructions
• Gauge Visor
• Reads: 0 – 100 PSI
• Electrical Gauge
• Free Tech Support
This Oil Pressure gauge measures the amount of oil pressure in the engine. A certain amount of oil is needed to maintain an adequate lubrication. Low oil pressure or the loss of oil pressure can result in costly damage repairs. Low oil pressure can occur and this gauge can properly view the engine's oil pressure with a quick glance. This is the most vital gauge needed in any after-market upgrades.
Old Jul 13, 2011, 10:08 AM
Give us a shout if you have any questions.
Old Jul 19, 2011, 10:02 AM
Any questions just give us a shout!!!
Old Jul 23, 2011, 09:31 AM
If you have any questions just give us a shout!
Old Aug 21, 2011, 09:20 AM
If you have any questions, concerns, or if you need a quote send us a pm or give us a shout through e-mail!
Old Aug 26, 2011, 01:59 PM
If you have any questions, concerns, or if you need a quote just send us a pm or even give us a shout through e-mail.
Old Sep 5, 2011, 01:38 PM
Old Sep 14, 2011, 03:03 PM
If you have any questions, concerns, or if you need a quote send us a pm or even give us a shout through e-mail! ! !
Old Sep 17, 2011, 01:29 PM
Give us a shout through pm or even through e-mail if you have any questions, concerns, or even if you need a quote!
Old Sep 22, 2011, 06:40 PM
if you have any questions, concerns, or even if you need a quote just give us a shout through pm or even through e-mail ! ! !
Old Sep 26, 2011, 06:17 PM
If you have any questions, concerns, or even if you need a quote just give us a shout through e-mail or even through a pm ! ! !
Old Sep 28, 2011, 02:13 PM
Old Oct 6, 2011, 02:14 PM
If you have any questions don't be afraid to ask!
Old Oct 7, 2011, 01:37 PM
Old Oct 10, 2011, 09:56 AM
Contact us through pm or through e-mail if you need anything!
Quick Reply: AEM Turbosmart Innovate etc. Wideband Kits, Gauges, and EBC At Mellon Racing
