Weapon R Ignition Equalizer Kit
The Ignition Equalizer Kit Amplifies the current being delivered to the ignition coil pack by stabilizing the current frequency. A bigger spark means more power, better throttle response and better gas mileage. This kit bolts on top of the ignition coil pack on cars with “Coil over Plug” ignition system. A 6 gauge ground wire is attached to the Equalizer Plate on top of the coils and to a ground on the vehicle. We use Platinum terminals and high quality 6 gauge wire. These kits are made for specific vehicles. Ignition Equalizer plate is made of High quality 6061 Aluminum and then polished to a high finish.
Designed to Equalize current to the coil packs amplifying the charge to ignition system. Increases Gas Mileage, Torque, Throttle Response and Horsepower.
Your price: $112.50 - IN STOCK
ORDER YOUR WEAPON R IGNITION EQUALIZER KIT HERE
Originally Posted by Deca Auto
Are you serious? All I have to say is ralliart spark plug wires are 70 bucks.
I wonder if, instead of the plate which cost $112.00, if you can just get some 8 or 10 gauge wire and link it up in series which I think would yield the same results for less then the price listed?
Originally Posted by vletnguyen
it only grounds two coils? what about the other two?
Originally Posted by mrdecibel
The benefits people have seen with grounding kits are related to ignition. By going directly to coil from battery is a lot less resistance. I would do this over a grounding kit.
