Full Cosworth Evo Head Build!!!!
Old Oct 25, 2006, 11:25 AM
Vivid Racing's Avatar
$4,500.00 For EVO 9 AND $4,450.00 FOR EVO 8 (Should be over 5k)
Here is what it that price includes!....
1. Shipping for all parts!
2. Cosworth Cams (of your choice for 8 264 or 272)!
3. Cosworth Head gasket (85 or 86mm)!
4. Cosworth Big Valved head!
EVERYTHING IS IN STOCK READY TO SHIP!!!(EVO9 cams on there way)!!!
High Performance Head Gasket, a must for high boost engines, Cosworth high performance head gaskets use multi-layers of stainless steel for increased strenght. The outer layers are embossed with a flouroelastomer rubber material designed to meet the demands of harsh sealing environments and load conditions.
Bore=85mm, T=1.0mm each.
Cosworth camshafts are ground on NEW chill cast cores to the highest standards. Each cam profile is carefully designed to maximize performance across the entire power band, producing strong power gains throughout. Prices includes two camshaft.
Duration 272
Lift 11mm.
NOW TIME FOR THE BAD BOY:
Cosworth CNC ported cylinder heads feature dyno tested and flow bench proven ports, engineered for maximum usable power. Each new cylinder head is ported on a 5 axis machine to ensure consistency and perfect port shape every time. Additionally, larger intake (+1mm) and exhaust valves (+1mm) are utilized to help increase flow. Cosworth CNC ported Big Valve cylinder heads come complete with a performance valve job, hi rev (max 10,500rpm) valve springs with titanium retainers and are ready to install. Perfect for high performance applications
Includes
CNC Ported - New Castings
Hand blended finish work
Intake ?26% (max) increased flow
Exhaust ? 18% (max) increased flow
4-angle Inlet Valve job
3-angle & radius Exhaust Valve job
Valves are lapped
Back-Cut Inlet Valves
Heads are Ultra Sonic cleaned prior to assembly
Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.)
+1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs
Titanium Retainers
Hardened Steel Spring Platforms
OK Also if you need timing belts(HKS) head studs(cosworth) and intake manifold gasket(AP) add-$390 (shipped
EVO9 CAMS LINK; https://www.evolutionm.net/forums/sh...d.php?t=229837
Old Oct 25, 2006, 04:23 PM
Bump!
Old Oct 26, 2006, 10:10 AM
bump!
Old Oct 26, 2006, 04:51 PM
Bump
Old Oct 26, 2006, 07:51 PM
G-UNIT's Avatar
that's hot b !!!
Old Oct 27, 2006, 09:05 AM
Werd! ... Bump!
Old Nov 2, 2006, 09:37 AM
Bump!
Old Nov 5, 2006, 02:31 AM
RaceReadyEvo's Avatar
man that head is sick... cosworth makes really nice motor parts
Old Nov 8, 2006, 05:18 PM
BUMP I can include a cosworth stroker kit for $4800.00 or a full short block for $8835.00
Old Nov 8, 2006, 06:21 PM
CoachG's Avatar
More info on the stroker kits. What displacement options (stroke and bore)? I have heard that Cosworth has 2.2l and 2.3l kits. The 2.2l seems like a great balance of the greater torque of a stroker (and better spool up) and the higher redline of a built/balanced 2.0l block.
Not that I can afford it but any discounts for the complete longblock? What would that cost...something like $14k! UGH...I need to win Powerball!
Thanks,
CoachG
Old Nov 9, 2006, 12:46 PM
That is the discounted price normaly retail is 9800.00. Yes this is a 2.2 l Fully assembled!
Old Dec 4, 2006, 03:11 AM
Evo_7's Avatar
Please quote cosworth pistons and rods
Lukas0120
Apr 30, 2017 08:51 PM
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
165
Dec 15, 2009 10:15 AM
SBR Inc2
Sep 11, 2009 06:19 AM
Speed Element
Feb 27, 2008 11:34 AM
Mark@AMS
Automotosports - Illinois
26
Feb 19, 2006 12:56 PM
Quick Reply: Full Cosworth Evo Head Build!!!!
