Slowboy 20g Turbo Package Upgrade!!!!!!!!
For the remainder of this month we are offering a special complete 20g upgrade kit deal. It included our SBR bolt on tubular manifold, 20g upgrade turbo and install kit....
***PRICE CHANGED DUE TO INCREASE IN TURBO PRICE***
....$1,185.00 SHIPPED!!!!!!!!!!!!
This is everything you need to directly bolt on the 20g to your EVO VIII-IX.
PM ME NOW BEFORE SUPPLIES RUN OUT!!!!!!!!!!!!!!
Joe
jws@slowboyracing.com
Joe
Dress up your cast IRON MAN!
JMFab Mitsubishi Evo Stainless Exhaust Manifold Heat Shield
We got these bad boys in stock, and wow are they sexy. Not to mention CHEAP!!!!
Pm me for some special offers right now on these heat shields!
Eric @ Slowboyracing
EP@slowboyracing.com
724 349 8417 ext 16
724 349 8417 ext 16
Domo arigato Koyo RAD
Looking for a new shiny piece under the hood, that must have some function, why not get a KOYO radiator
Koyo Evo 7 and 8 All Aluminum Racing Radiator
PM Eric at EP@slowboyracing.com
AIM : peteypab2133
- Koyo Radiators are fully polished to a mirror finish
- Koyo Radiators provide 20% to 30% more cooling than standard radiators
- Koyo Radiators handle high revving, high performance engines
- Koyo Radiators are perfect for Turbo Charged, Super Charged & Nitrous Oxide equipped engines
- Koyo Radiators are made from aircraft quality aluminum and heli-arc welded, cores are NOCOLOK-brazed
- Koyo Radiator is on the cutting edge of technology and design with Japan's largest automobile manufacture
- Custom built OEM fit - All Koyo Radiator cores and tanks are specifically designed and built for each application. No universal fit parts are used. This ensures proper fit, just like your original equipment.
- Koyo Radiator builds radiators to fit today's most popular import performance cars.
AIM : peteypab2133
Im pickin up good vibrations, Shes giving me excitations
Fluidampr Mitsubishi 4G63 Crank Pulley
The inertia ring inside Fluidampr shears through a thin film of highly viscous silicone fluid to effectively control harmonic vibration at all engine speeds. But what is silicone fluid really like? Well, fluid is somewhat of a misnomer because it is really more like a gel. The silicone fluid used in Fluidampr is clear in color and is more than 45,000 times thicker (more viscous) than 30 weight motor oil.
Silicone fluid is a very good damping medium because it is relatively unaffected by temperature changes. Thus, it provides consistent damping in both winter and summer. The fluid does not harden or change viscosity if Fluidampr is not used for a period of time. The fluid is so durable that big rig, 18 wheeler truck engines are mostly all equipped with viscous fluid-type dampers.
Silicone fluid's damping capability is unmatched. That's why the fluid inside Fluidampr is guaranteed for as long as you own it.
Balance - Internally Balanced
Material - Aluminum
Finish - Anodized Gray
Applications - Tested to work great on street or race cars
Outside Diameter - 6 3/8"
PM ME FOR THE BEST PRICE !!! YOU KNOW YOU WANT TO!!!
Pm Eric
"Give a man a match, and he’ll be warm for a minute, but set him on fire, and he’ll be warm for the rest of his life."
Material - Aluminum
Pm Eric
Aps 3.5" Tbe In Stock!!! Ready To Ship
A true bolt-on 3.5" turbo to tip race exhaust Crafted in premium 304 stainless steel and designed for 600+ horsepower. Minimal exhaust back pressure, fast turbocharger spool-up and maximum horsepower is guaranteed.
The APS DR Series 3.5" Turbo to Tip Race Exhaust is a true 3.5" internal diameter exhaust system through each and every section. By utilizing the latest technology precision mandrel bends with the smallest possible bend angles spread over the maximum possible length, optimum exhaust gas flow minimum exhaust back pressure is achieved.
The comprehensive APS DR Series 3.5" Turbo to Tip Race Exhaust system includes 3.5" internal diameter 304 grade down pipe, 304 grade 3.5" internal diameter intermediate pipe, Highly polished 304 grade 3.5" muffler, 4.5" tip assembly, all mounting hardware, gaskets, stud, nuts etc. for easy installation.
$990.00 SHIPPED
Email Eric
724-349-8417 ext 16
"Let off some steam Bennett"
The SlowBoy Racing Heat Barrier Gasket, which is used in conjunction with any Evo VIII intake manifold (stock or aftermarket). This unit replaces the stock gasket and forms a heat barrier gasket between the intake manifold and the cylinder head. If your ever running without one of these, try touching your intake manifold after operation, you will probably burn yourself. With one of these gaskets the manifold will only get luke warm and remember cool air makes more power
PM me for the best price !!
EP@Slowboyracing.com
Inject yourself....
Need to pump up the volume?
Got a bigger turbo? wanna run E85???
Get some FIC injectors!!!
FIC's (850cc, 950cc, 1050cc, 16000cc) injectors for high horsepower applications. A good fuel management system is a must with this size of an injector.
PM me for our best possible price!!!
724 349 8417 ext 16
724 349 8417 ext 16
Chances are this guy isnt bringing you anything this year...so leave it up to us! Anything from now until Christmas is free shipping on everything in stock! Any orders over $500 will get some free bee stuff to be a sweet stocking stuffer...minus the stocking.
PM ME NOW!!!!!
Joe
pimp the hose kit out!!!
Samco Sport Mitsubishi Evolution 8 and 9 Coolant Hose Kit
Tired of the boring look of the plain black rubber hoses. Upgrade to the SAMCO silicone hose kit that is not only better looking but also handles the pressure and heat that you've always dreamed of!!!
This kit is made of silicone rubber and will provide the high quality performance and protection you need. The hoses are good for temperatures up to 338 degrees Fahrenheit while fitting in the stock OE location.
There is a difference believe it or not between the 8 and the 9 so please specify when you call or PM
Available in most colors!!!
PM me for the best possible price shipped to your door!!!!
Eric
Eric
