3-port plug-n-play boost control solenoids!
we now have 3 port boost control solenoids in stock! these will plug directly into the OEM boost control plugs, enabling you to run your car just like a electronic boost controller costing hundreds of dollars.
we do have limited quantities though, as the valve take a very long time to get we assemble these in house, so you wont find these sold anywhere else
it will work with the evo 8, 9, X, and ralliart.
click here to order one! $70+ shipping (5 dollars).
3 - port BCS
3 - port BCS
these valves function the exact same way as the GM 3 port. although we use a different valve so it looks slightly different. the valve we use is identical to what you would find on a AEM true-boost, or a greddy profec B. except we change the connector and add a resistor to make it identical in impeadence to the stock solenoid.
FS[Northeast]: COBB 3-port Boost Solenoid
Dmotorsports
Feb 5, 2016 03:52 PM
maperformance
21
Oct 27, 2009 03:14 PM
