**HKS GTII 7460R Turbo Upgrade Kit for Evo 4-9 @ Mellon Tuning!**
Old Feb 8, 2011, 12:18 PM
Mellon Racing's Avatar
As a true bolt-on upgrade for the Mitsubishi Evolution IV-IX, the GTII 7460R is a reverse rotation ball-bearing turbocharger assembly that utilizes the factory exhaust manifold.
By creating a twin scroll, reverse rotation turbocharger, the GTII 7460R offers a straighter exhaust path to the turbine housing inlet increasing boost response while allowing full spool and stable boost pressure throughout the RPM range.
Intake and exhaust port sizes have been optimized in size and flow area to allow an increase in air-flow capacity while the ball bearing center housing rotating assembly (CHRA) improves low-speed boost response.
The inconel turbine wheel and heat resistant SUH 22 cast stainless steel turbine housing increases reliability and durability. The GTII 7460R produced 373.4 WHP and 355.6 ft. lbs Torque with the boost set at 1.78 Bar (25.8 PSI) on 93 octane.
Check it out here: http://www.mellontuning.com/index.ph...roducts_id=780
Let us know if you have any questions or to request a shipping quote!
Mellon Racing is offline
Old Feb 9, 2011, 12:43 PM
MMMills89's Avatar
Was that on a stock motor other than the turbo
MMMills89 is offline
Old Feb 9, 2011, 01:06 PM
Tested on a HKS prepared 2006 Mitsubishi Lancer Evolution IX with the following parts:
• GTII 7460R Sport Turbo Kit
• R-Type Intercooler Kit (with EVO IX fitment kit)
• Step1 Mivec Camshaft Set
• Racing Muffler
• GT Extension Kit
• F-Con V-Pro
• Fuel Upgrade Kit (800cc Injectors & Fuel Pump)
• Racing Suction Reloaded Intake Kit
• EVC
• Super Fire Racing Spark Plugs
I'm pretty sure we can do better than that with a car that chose our mod path
Old Feb 23, 2011, 07:38 AM
ttt
LCS
19
Feb 9, 2017 11:15 AM
HKSUSA
HKS
12
Feb 15, 2016 01:00 PM
evoxmr08
Mitsubishi TC-SST Discussion
14
Nov 30, 2011 01:12 PM
mrfred
168
Jun 18, 2011 09:08 PM
Touge Factory
19
Oct 7, 2010 01:02 PM
Quick Reply: **HKS GTII 7460R Turbo Upgrade Kit for Evo 4-9 @ Mellon Tuning!**
