Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
Lowering Spring Master Thread - Personalized Service and Unbeatbale Prices Guaranteed
Old Oct 4, 2012, 02:59 PM
maperformance's Avatar
Thats right, all Swift products are on sale. Don't mess around with those guys hanging out in their parents basements who never answer your calls, they don't know the first thing about customer appreciation!
Let us know what your looking for, and we will have it to your door in a jiffy!
Swift Sport Springs (4M008/4M017) $299.25 Shipped
Swift Spec-R Springs
(4M008R/4M017R) $314.25 Shipped
Eibach Pro-Kit Lowering Springs Mitsubishi Evo 8/9 (6041.140)
ONLY $244.99 Shipped
Advantages of the Eibach Pro-Kit:
* Excellent ride quality - comfortable in cruising
* Sportive handling in cornering, resulting in improved performance
* Lowered center of gravity, increased stability
* Enhanced appearance of vehicle
* Manufactured according to ISO 9001 quality system as well as T/V approved
*1" drop front and rear
* 10 year product warranty
We also carry other high quality brands such as Tein (H.Tech and S.Tech), Works, H&R Race or Sport Springs, Tanabe GF210 Only $196.99,
Skunk2 and...
Megan Racing EVO Lowering Springs Kit (MR-LS-MELEVO8) For Only $139.99 Shipped!
If you have any questions on the above products, feel free to give us a shout. We are all ears from 9:00a.m. to 6:00pm. Central Time!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: NateAtMAP|||||: 1-888-MAPERFORMANCE x 114|||||: Nate@MAPerformance.com
Like us? Tell us and everybody else about it!
maperformance is offline
Old Oct 5, 2012, 08:33 AM
Check out the "Featured Manufacturers" section of our site!
Old Oct 8, 2012, 07:58 AM
MAPerformance stock frame turbos for Mitsubishi EVO!
Old Oct 9, 2012, 08:07 AM
MAP EVO X Package deals!
Old Oct 10, 2012, 07:51 AM
MAPerformance, your BEST source for Turbosmart Wastegates, Blow Off Valves, and all sorts of boost related goodness!
Old Oct 11, 2012, 08:44 AM
MAPerformance EF Series EVO 8/9 Turbos. Power, reliability, performance...all in a stock frame package!
Old Oct 12, 2012, 02:25 PM
Old Oct 15, 2012, 07:53 AM
Valvetrain, drivetrain, brakes, fueling...it's all here in the "MAP Package Deals" section of our site!
Old Oct 16, 2012, 08:09 AM
Stock frame EVO 8/9 and X Turbos? MAP's EF series of turbos has you covered!
Old Oct 17, 2012, 07:58 AM
Old Oct 18, 2012, 08:06 AM
Old Oct 19, 2012, 07:51 AM
Finally, a fuel feed line solution for your EVO X!
This MAP fuel feed line kit replaces your entire factory feed line from the fuel pump housing to the fuel rail with 6an hose. Supplied push-on EFI fittings allow for an easy installation that requires no modification to your fuel pump housing or fuel rail!
Why replace your factory fuel feed line? Restrictions in the factory line cause pressure drop from the fuel pump to the rail; depending on the application a fuel pressure reading at the fuel rail might be 5, 10, or even 15psi lower than the fuel pressure at the pump. Take a gander at any fuel pump flow chart and you will find that fuel pumps flow significantly less at higher fuel pressures. To put this into perspective a Walbro 400lph fuel pump flows roughly 253lph at 90psi (13.5 volts) in comparison to 300lph when pressure is reduced to 75psi. An additional 50lph translates into almost 100whp of additional fuel capacity on E85!
This kit is available with or without a FueLab inline filter, however, please keep in mind that any aftermarket fuel pump (outside of the DW65C) will eliminate your factory in tank filter making this a pretty good idea.
Old Oct 22, 2012, 08:37 AM
Did you know that ALL MAP Fab in house manifolds are built with the following features?:
100 Percent polished schedule 10:
MAP invested hundreds of hours into developing a system to polish schedule 10 to our specification including research into the best possible tumbler, sampling a wide array of aggregate to generate the perfect finish to start with.
All manifolds welded on back purge stations
ALL MAP in house fabricated manifolds are tig welded and 100 percent back purged. This a process by which shielding gas is introduced to the interior of the welded area to prevent the molten metal from being exposed to oxygen. This results in stronger, more uniform and cleaner welds.
All MAP in house fabricated manifolds come with thick, laser cut/cnc'ed stainless flanges
Resulting in longer lasting and more aesthetically pleasing parts
All MAP in house fabricated manifolds come ported
Where some companies will simply grind away excess material for a simple transition into the runners, MAP manifolds are actually ported and shaped for maximum flow.
All MAP manifolds are backed by our Lifetime Ownership Guarantee!
When purchasing a MAP manifold, purchase with confidence. We guarantee that manifold for the lifetime of your ownership of it (valid for the original purchaser only).
MAP Complete T3 Turbo Kit (Mitsubishi Evo X)
The wait is finally over as you can now get the MAP treatment in a T3 configuration using some of the best components available! Choose from four killer PTE turbochargers (please don't hesitate to contact us for suggestions) and turn your horsepower dreams into a reality. This kit includes every component you will need to complete the installation.
Included Components
Turbocharger of your choice
3" Stainless Steel V-Band Downpipe with Flex
304SS Tubular Exhaust Manifold with CNC Transition Head Flange to 1.5" Primaries
Cam Angle Sensor Heat Shields (not pictured)
Turbosmart Comp Gate 40 Wastegate
Wastegate Dump Tube
Stainless Steel Upper Intercooler Pipe
Oil Feed and Return Lines
All Applicable Gaskets, Hardware, Clamps and Couplers
Old Oct 23, 2012, 08:59 AM
MAPerformance - Your source for everything Turbosmart
Wastegates, Blow off valves, boost controllers...Turbosmart has your boost needs under control
Old Oct 24, 2012, 08:18 AM
MAPerformance stock frame turbos! Available for the EVO 8/9 (EVO 8 will require a conversion kit to fit an EVO 9 turbo available through us as well!) AND EVO X!
Power, reliability, affordability all in a stock frame turbo? It's as simple as that. MAP turbos use our MAP Billet wheel, dual oiling ports for improved lubrication and all EF3, EF4's include upgraded thrust bearings. Simply put, MAP is your answer for your stock frame turbo needs!
Customer satisfaction is our highest priority!
If for some reason you are not happy with your MAP turbocharger simply send it back to us within 30 days from the date of purchase and we will refund you 100% of your purchase price for that item.
Please note the turbocharger must not be damaged or altered in any way, and all accessories must be included within the return shipment.
Quick Reply: Lowering Spring Master Thread - Personalized Service and Unbeatbale Prices Guaranteed
