Help! Evo 5 Roof Rust Problem!
Old Nov 22, 2010, 12:24 AM
jameswwt's Avatar
Hi,
can anyone share or advise on how to permanently or at least can last up to 5 years to remove roof rust and what chemical and steps should i do for the sake of saving the roof?
Thanks
Old Nov 22, 2010, 12:50 AM
BCspeed34's Avatar
I have the same problem, Mitsubishi used a poor roof sealant (that goes between the roof supports) which held moisture, in turn creating nice rust spots.
Only solution is to find a complete roof off another Evo, or a Lancer/Mirage. Another solution is carbon fiber roofs, or you could have the spots cut/replaced with sheet metal. And if you want to ignore it, you can grind away the rust, put in some body filler, and paint over it all.
I will likely find a replacement roof (possibly with a sun-roof) to swap over. It's starting to get pretty bad, things are starting to rattle up there at high speeds
Old Nov 22, 2010, 02:35 AM
jameswwt's Avatar
Hi,thanks for sharing and where are you from? im frm Malaysia and have you change the roof?
Old Nov 22, 2010, 06:10 AM
MaD_CaNaBiCe's Avatar
You could get a good bodyman to mold a fiberglass roof from your current roof but I would advise that if you get a fiberglass or carbonfiber roof to put a roll cage inside for safety.
Old Nov 23, 2010, 02:10 AM
jameswwt's Avatar
Is there any chemical where i can eliminate the rust once and for all?
How abt power coat? can i take out the roof, remove the rust and send it to power coat?
fujirio
Outlander Sport
19
Mar 1, 2021 11:35 AM
TheMasongtre
Dec 12, 2019 04:28 PM
4g63girl
Feb 6, 2016 08:00 AM
dawhoo
Outlander Sport
Nov 17, 2015 05:24 AM
RallySport Direct
Evo 'For Sale' Exterior Styling
44
Sep 1, 2015 09:24 AM
Quick Reply: Help! Evo 5 Roof Rust Problem!
