*** Official Plasti Dip/Flat/Matte Evos Thread *** [MERGED]
So I Plasti Dip'ed my wheels today
Stock
Taped
First coat still wet
Dry finish
On the car (a small photo shoot)
This is the first time I have done this. I made a few mistakes but I mostly want to see how long the stuff can last and how it holds up. The next time I will correct the minor issues I caused myself.
Other than that I think it makes the car look better and certainly the wheels since the previous owner used some pretty harsh stuff on a couple of them that left them looking bad in areas.
Taped
Dry finish
http://www.plastidip.com/industrial_...ons/Plasti_Dip
I was talking about it with a guy at work a week or so ago and a few days after that a thread popped up here. By that time i had already bought the cans and was waiting for the day.
I three thick coats so I used just barely over three cans. It evens out as it dries. You do one coat and wait 30 min. to do another coat then four hours to dry.
There are a bunch of videos on YouTube that show people taking it off. I want to see how well it lasts on back roads and a wash.
As I said in the OP I made a few minor errors this time around but learned from it and it is fixable so not harm no foul.
Why not?
Nothing permanent and I like the black wheel look, besides the wheels look worse up close without the coating, thanks to the previous owner.
Powder coating costs a fortune and has more down time. This can be removed and a different color if one wanted.
Or is it only when one spends a ton of money on things that it makes it desirable?
Have a nice day by the way.
Been there done that the reason why evonub is trippin is your wheels are going to be chipped and nasty looking in no time. I even went a step farther and sanded my stockers and removed the stickers and they still chipped like crazy with the "wheel paint" and the clear coat as directed. Rattle cans are for arts and crafts, the wheels simply take too much abuse.
It peels off. If they start to look "chipped" (hard to do when it is rubberized finish, but possible) I can peel it off. No sanding needed, no finishing it with a clear coat. None of that.
This is an experiment. You people "trip out" far too easily without reading things properly.
Multi-purpose air dry, synthetic rubber coating that can be easily applied by spraying, brushing or dipping. Plasti Dip resists moisture, acids, abrasion, corrosion, skidding/slipping, and provides a comfortable, controlled grip. Plasti Dip protective coating remains flexible, stretchy and will not become brittle or crack in extreme weather conditions; -30°F to 200°F. Available in 7.25-oz Can, 11-oz Aerosol, 14.5-oz Can, 1 Gal, 5 Gal, 50-Gal Drum - UV and Fluorescent Formulas Available in 1 Gal, 5 Gal, 50-Gal Drum.
