Custom Headlights
Custom Headlights
I was wondering if anyone could help me ID the modifications below on the Evo 8/9 headlights in the pictures attached below (not including the eyelids). I really like the Angel Eye look in this application because it seems to fit rather well. I'm not too sure if the headlight housings are blacked out or not, but they look like it. Are the signal lights permanently on vs the parking lights?
Any info on how to achieve this would be much appreciated
I drive a 04 VIII GSR with USDM headlights if that helps.
Looks like blacked out housings. Probably just baked it open and installed something similar to what can be found here. simple install, just buy a couple of these halos and figure out a way to mount them. They are probably different than a 100mm one, just using these as an example
https://www.amazon.com/s/ref=nb_sb_n...k%3Ahalo+100mm
that's just a piece of vinyl over the top section of the headlight, commonly known as eyelids. many cars have aftermarket plastic ones that clip on or adhesive on somehow
doesn't look like any modifications in the headlight, just the flash from the camera reflecting back off the high beam housing
quickflips
Mar 12, 2012 10:00 PM
quickflips
Feb 28, 2012 10:53 PM
ev0lution9
Jun 26, 2010 11:02 AM
