Wheel \ tire side wall question
OK i forgot how this goes but here is a example.
you have 1 8.0 width factory wheel and 1 8.5 width wheel on a factory size tire of 225/45/17.
Ok going from a 225\45\17 to a 235 or 245/40/17 would it make the side wall smaller or a bit higher. yeah obvious i said 45 to a 40 but using both widths from the top and wider tire.. what would the side wall look like? Higher or lower. I just remember something about even if you go down a size in sidewall and wider or smaller width tire\wheel it changes sidewall differently.
Explain because i am obviously clueless
Example: 225/45-17
1) 225 is the nominal width of the tire in millimeters.
2) 45 is the aspect ratio - how tall the sidewall is relative to the width of the tire (in this case, the sidewall height is 45% of the tire's width).
3) 17 is the diameter of the wheel that this tire would fit.
In this example, the sidewall measures 101.25mm.
A 235/40-17 would have a sidewall height of 93.6mm and the 245/40-17 would have a sidewall measuring 98mm.
Both would be shorter than the 225.
Wheel width does not affect the tire's height (well, actually it would in fine measurements but we're not going there.)
-Paul
Boltz.
19
May 28, 2011 06:13 AM
VT Mitsu
28
Apr 15, 2010 09:18 PM
