Resurfacing rotors question?
Here is the story b4 I ask the question:
I took my car in for one of its services and I was told I needed new break pads and my rotors needed to be resurfaced. Ok well the pads thing I was expecting because I can feel that it wasn’t the same as it used to be, but the rotors caught me by surprise. They wanted to charge x amount to do it…let’s just say dealer price. I told a friend of mine and he is going to help me get the pads and such cheaper…but he had notices when he was looking that it is recommended that the rotors be turned on a “on the car” break lathe.
So here is the question, to turn or resurface the evos stock rotors do you need to use an “on the car” break lathe or a normal break lathe?
you can use whatever brake lathe you want. The only time you really need to resurface rotors is when there is a shimmy/warped rotor. Some cases you will need new rotors when they get warped due to it being crappy metal. Most shops resurface rotors on a lathe for every brake job. Some only do a pad slap. Me personally for my car, if the rotors are within spec then i'll resurface them. If there is a shimmy/warped i'll get new rotors. If they are pitted then i'll get new rotors.
you dont need to use on the car brake lathe that was just an invention for lazy people who dont want to take off the rotors.. lol
but seriously either type of brake lathe will work as long as they are correctly turned..
as for turning the rotors you really only need to turn the rotors when you feel excessive vibrating in the steering wheel from them being warped... other than that if they feel fine you should be able to just change pads without resurface.
i would also machine the rotors if they are glazed. im surprised that a lot of people ar unfimailiar with this.
a glazed rotor is kinda like when you peel off a sticker and the adhesive is still on the surface and you try to rub it off with your finger but you cant.
the glaze on the rotor acts as a barrier between your pads and rotor, reducing your braking performance. you wont feel a shimmy or vibration but your car wont stop as well as before.
also, you'll need to resurface/replace your rotors if they sre scored, in other words, have grooves in them. run your fingernail across the rotor surface and if you feel it catching, get them fixed. it should be smooth.
so remember, just because you dont feel a vibration in your steering wheel doesn't mean you dont need a resurfaced rotor.
just ask your mechanic/service writer to see why your car need the recomended work done.
ask them to show you the problem and explain how it effects you and your car.
I pulled the tire so i could feel it myself, the rotor has a lip on the inside and outside edge, maybe one 8th of an inch around. I dont think its suppost to be there...also the rotors are "wavy" like I can feel its not flat. Other then those I dont see anything wrong, ill prolly have them turned on a regular lathe...unless anyone tells me otherwise.
stefenboy
Sep 19, 2016 09:04 AM
sykou
Mar 8, 2006 12:45 PM
sanjaya1
18
Dec 27, 2003 06:12 AM
amigoni
14
Aug 26, 2003 10:14 AM
