The Official Wide Tire Thread
#721
Looking to pick up a set of wheels/tires for my evo9. The car is 99% street car, and will probably only see an autoX or two next season while I get used to it (I'm new here...). This doesn't mean that I don't give her the beans every time I see a twisty on a back road...
My goals:
- 245 or 255 wide tire
- 17 or 18 inch wheel, though I typically like a smaller wheel for moar rubber (sidewall)!
- little/no body modification outside of a moderate roll if necessary
- more aggressive than stock fitment
- MUST be square
- would prefer to not run spacers as that's just more $$$$$$ (studs, etc)
I'm not partial to RPF1's, but that's probably where I'll land (cuz light/cheap/sexy).
Do I go 17x9.5 wheel +15 offset? Do I go 18x9.5 +15?
Do I go 245/40/17 tire? 245/45/17? 255/40/17? 255/35/17 (too 'short'?)?
How about 245/35/18? 255/30/18? Maybe 255/35/18 (this seems too tall...?)?
Also, someone talk me out of Michelin PSS's... I just went through my first set ever, and I loved them too much, but they cost noticeably more than their (more or less) direct competition. Anyway, I'm in the market for a set of summer performance tires that won't burn off in one summer of driving. For reference I've owned Hankook v12 Evo's, Michelin PSS's, Continental Extreme Contact DW's. They were all good (Mich. PSS's being my favorite), but I'm just looking for opinions.
This thread is absolutely awesome by the way... I'm sure I'll be coming back here and stealing knowledge in the future when the evo goes track machine in a few years!
My goals:
- MUST be square
#722
17x9.5 +38 rpf. Roll the back fenders, perfect fitment for a responsive 255 tire and easy to rotate. +15 will not fit the rear the way you want. Will need 20mm spacer up front. No big deal; many of us road race with spacers.
Light and cheap.
Hankook R-S3 is cheaper than the PSS and grips better. For a step up in responsiveness, I went with RE71rs.
I'm not sure I'd want to daily that sticky of a tire, though a lot of people do.
Light and cheap.
cerevo (Apr 27, 2016)
#723
Light and cheap.
Light and cheap.
/e: my confusion lies with seeing lots of people run four square wheels/tires but spacing the front. I understand this is to clear the front calipers, but I'm surprised to think that this doesn't make the front 'poke' more than the rears...
#725
Yikes, aparently I was tired when I first responded this morning...
Anyways, thanks again for the advice, and thanks for the sick action shot!
I am very tempted to put a 'stockish' fitting setup on the car simply because it'd be easier/cheaper (apparently 17x8.5 +30 RPF1s fit under the body no sweat and clear the brakes with no spacers because of their spoke shape), but I really want 255+ wide tires, so I'll wait and save a bit more.
On another note, seems like some of the tire manufacturers don't make 255+ wide tires for a 17 inch wheel (talking about Mich. PSS's specifically....). Maybe I'll splurge and go for 18s just for a wider selection of tires.
#726
For wide tires, you will want wide wheels. The wider wheel helps stretch the tire out a bit, which results in a marginally wider effective contact patch. The opposite is true if you go to a narrower wheel. Having the wheel very mildly stretched also helps for stability of the tire and general feel of the car, which counts for a lot more than you might expect. Those 8.5" wide wheels will get the job done, but not as well as a 9" or 9.5". Also the spoke pattern looks really ugly on those, IMO.
If you're budget-conscious, steer clear of 18s. 18" wheels and tires are a significant step up in price. But you're right, if you want to go past 255s you need 18s.
#728
I stick with 17s because I like the cost of wheels and tires. I'm not at a place where I can go wider than a 255, so there really is no point for me, anyway.
I do feel a wider track in the front looks better. The front fenders seem to sit wider than the rear. Don't know, though, I've never measured. I've read a wider track in front is a good thing too, but haven't confirmed with any real data. Just info on what Japanese groups run.
#729
It's not just Japanese groups, a large majority of the track guys are running wider front track. Simply put it just works. I posted a couple links in the evo x control arm thread about the physics behind it, spacers actually change scrub radius and affect weight transfer and therefore grip. There's an old thread around where someone did the math on the change in weight transfer by a 15mm or so increase in track width, I believe it was around 2% in the beneficial direction.
Stock the front and rear track width are equal, think it was around 61 inches.
A few r comps are available in 275/x/17's but most sticky street rubber we run now days a 255 is damn near a 265 anyway
#730
Kaj- I'm going with the same set up.You went with apr wheel studs and open end lug nuts?With 255 how's launching the car?With the stock 235 tires it's not to hard on the drivetrain but with 255 tires,I know it will be harder on it.
#731
i don't launch my car, so i can't really say how they do.
#734
Bolt on spacers definitely need to be properly torqued, hammering on with an impact is bad juju. Red Loctite is also recommended.
#735
i use them as well, although im planning to go to slip ons and extended lugs shortly because my second set of wheels dont fit with them due to not having cut outs on the back of the hub.
i did crack one at one point, however im not sure if it was a result of over torquing or not. current set has been on the car for 2.5 seasons with no issue.
i do come from the camp of believing that they are in fact slightly risky and arp studs are better.
