Speed bleeders for the Brembos?
#31
Just wanted to update the info I have while I was researching the correct numbers back when I was looking for them. Hope they help.
Brake bleeder spec: 10mm x 1.0 x 33mm(31mm will work also)
Pepboys #12706 $9.89/pair
NAPA #675-1570 $11.69/pair
Kragens #12706 $11.xx/pair
Speedbleeder #1010S $14.xx/pair
Clutch bleeder spec: 10mm x 1.0 x 35mm
Clutch Slave speed bleeder
NAPA #675-1573 $11.xx/pair
#37
a few things on this. firstly the nut section is a 3/8", so your evo friendly metric tools will strip.
secondly don't turn it any more than 1/8 turn, bascially BREAK the bolt... adn then start pumping... any more and you will suck air through the threads.
thirdly... i highly do not recommend DEPENDING on these, they're great for insurance... but i've bled my brakes 4 times now and i'm kinda pissed after 6 bottles of motul.
mind you this is the SECOND (second overall time) time i've done it with speed bleeders as the first time i only messed up twice.
#38
I just did this on Sunday when I put my summer wheels back on. Had to go to 3 different PepBoys stores to get enough bleeders because each store only stocks a maximum of 2 packs of p/n: 12706. The one store had an extra bleeder in a pack that someone opened so I got that one for free . I tried it out on the clutch slave and it works so I kept it in there. Clutch pedal feels is much better now. I guess the 1/2 dozen times I bleed the clutch line before still didn't get all the air out.
The procedure was very straight forward. Previously when I bleed the system about 6 months ago I thought I had all the air out of the lines but it turns out I didn't. Now I can honestly say my EVO is stopping like it should be .
I have a track day coming up in November that I'm going to try some high performance brake fluid for. Currently I'm using a run of the mill brand which exceeds dot 3 & 4 specs.
#39
AlwaysinBoost,
Did you bleed your brakes with the engine idling? I am getting frustrated bleeding my brakes (I have speedbleeders), still have a low, soft pedal after 2 rounds of bleeding, but I haven't tried bleeding with the engine idling as per the service manual.
#40
Originally Posted by Barnettevo
AlwaysinBoost,
#42
#43
So. I know this is an old thread, but looking to get some speed bleeders for my 03 ES for my clutch.....
Is it a M10x1.0?
I see the part numbers mentioned in this thread correspond to an M10x1 --- but someone mentions an M11?
Is it a M10x1.0?
#44
Here is my speedbleeder order information:
Order Contents:
Product ID Product Name Qty Unit Price Total Price
SB1010SS SB1010-SS Speed Bleeder 9 $15.00 $135.00
SPEEDBLEEDERHOSE Bleeder Hose 1 $3.00 $3.00
THREADSEALANT Sealant 1 $10.00 $10.00
Hope this helps... so I don't think you want M11.
EDIT -- the only question I still have is whether or not you really need the longer length speedbleeder for the clutch slave... If anyone can confirm, that would be great. I'll order a new part if necessary.
HanYsolo
Dec 11, 2017 01:07 AM
WTB[Northeast]: WTB Rear Brembos / Rotors / Lines
slowx
Nov 21, 2017 03:19 PM
WTB[West]: EVO X parts = Bumper beam / brembo's
racer98
Nov 14, 2017 02:00 PM
OneCrzyEvo21
May 24, 2016 10:34 AM
WTB[Northeast]: SE IX factory front lip.
True Blue
Apr 11, 2016 09:19 AM
