A lot fo smoke after hard braking
Was out for a short run yesterday night and did 3 or 4 hard braking before the corners, when car stopped at the traffic light, a lot of smoke came out from the rear wheel or rear underneath, was worrying something might go wrong so I pulled over and check, but no more smoke coming out.
Was it because of the Endless brake pad? or brake fluid leaking through calibers? Brake fluid level still looking good. I believe it has nothing to do with tranny/diff oils.
What could possibly be causing the smoke coming out from the rear wheel after hard braking? Or it is normal?
Thanks.
Thanks.
While smoking is not normal, under hard braking your front pads get much hotter than the rear; So the front should smoke before the rears.
What did it smell like?
Friction material (pads) and brake fluid have very distinct (and different) smells. For that matter, it could have been rubber or plastic as well (if it was rubbing); again a whole different smell.
Take your rear wheels off and inspect your pads and calipers. If the smoke was from brake fluid, you might have broken/worn a seal on the caliper piston. Moving it back and forth might reveal fluid if it's bad.
i have seen pads smoke (and even catch fire once) while on the track, but that was after EXCESSIVE brake usage. i would be a bit concerned if it was only after 3 or 4 hard uses.
how long were you on the brakes for? did you notice any fade? is it possible that a brake line or strut/shock has a small leak in it and was dripping any kind of oil on to the hot rotor? what color was the smoke?
and lastly, exactly how much smoke are we talking here?
i have also seen it happen before where after a hard bought of acceleration some oil gets burned and kicks some white smoke out of the tail pipe.
does everything seem to be operating normally now? pedal feel, stopping distance etc?
i would get under and take a close look at the caliper just to verify that there is nothing leaking from it anywhere.
Thanks for the replies.
Binarysleep, exactly what I was thinking, the front should smoke before the rear. It was like I have just done a burn out But all the smokes went away after a short 1 minute drive and pulled over and check, nothing wrong, no smoke no smell. Brake luid is still looking good.
MondoBongo, the brake is still working good. The color of the smoke is white.
I have taken off all 4 wheels and checked, no sign of oil/fluids leaking.
Maybe its the rear caliper piston failure? Is it an easy fix?
Also, the paint on the brembo calipers are peeling off.
if it is white smoke i would be leaning towards burning oil.
i remember specifically once at the autocross watching one of my buddies run, and as he was coming off course his evo started belching more smoke than the car from Spy Hunter (if you remember that video game )
i have heard that this is not entirely uncommon in turbo cars. occasionally under hard use some oil will get forced up in to the head and spit out into the exhaust causing it to plume white smoke like crazy. i can't vouch for the accuracy of that statement, but my friend has never seen the smoke again from his car, and the vehicle doesn't seem to be any worse for the wear.
check your oil level, see if you're lower than you should be, or would expect to be. it could be something like. also maybe take a look around your engine bay, make sure nothing is leaking from your oil plug, and also check your dipstick to make sure it is seated properly. sometimes they will work loose a bit too and spew some oil around.
good luck man! let us know if you find any other clues or figure out what it is.
When you took the wheels off, did you remove the calipers, or at least the pads? You can usually push the piston back and forth a little. This might reveal fluid.
i hope you find the source of your smoking. it is also possible that some piece of something or other got caught in between the dust shield and the rotor, and once the brakes heated up caught fire.
honda-guy
25
Aug 16, 2012 01:51 AM
