Whiteline vs. Energy suspension bushings - thoughts?
Any thoughts on the Energy suspension polyurethane bushings versus the Whiteline bushings? Seems like a lot of track guys are running the Whiteline bushings. Looks like the Energy bushings are a little bit more reasonably priced, so the question is: How do they compare to the whiteline bushings?
l8r)
l8r)
lol well ive had it done for 2 days. then I parked it. and now im on a military contract 3000 miles from home.
Basicly - get the graphite impreg'd ones(black) over the plain ones and you should minimize noises.
All i know is - it was hell to get them all in and done - but omg -- its a new car. If you have the chance at a meet to ride in one with out them done, and then another with them done.. you will see.
Get the black ES set for a car that sees any daily duty. They are FAR more quiet than the Whiteline. HOWEVER, I believe the Whiteline have a higher durometer, so they should be more solid for a track car if that's what you need. Just that the few cars I've heard with them sound like a Sherman tank after a few thousand miles. Just don't use the big fat donut bushing in the ES kit for the trailing end of the front arm.
l8r)
That was recollection... I seem to recall (but could be wrong) that the durometer is higher on the Whitelines. Which would mean that in theory there would be less compliance. Fact of the matter is, I can't see anyone NEEDING more than the ES kit. So you got the gist of what I meant. I would not do the Whitelines myself. The examples I've seen were noisy as hell after the initial lube pushed out of the bushing miles later.
Whiteline Plus poly bush compliance
G'day everyone,
Hope you don't mind us popping in late but we've just been told about this thread.
We can't really comment on other brands but I can tell you that we have quite a different approach that doesn’t necessarily suit everyone. The Whiteline range is deliberately designed to be as soft as possible using the inherent benefits of polyurethane in engineering grades to overcome some of the short comings of rubber.
I would think that if anything, our product would probably be softer than most and that's pretty consistent with the industry as a whole in Aussie as we've successfully been using poly as a direct replacement for rubber for many years. The Whiteline Plus range was developed as an extension of that with "progression" being pretty important in the design. For those interested in you can take a look at http://www.whiteline.com.au/Plus/product.htm for more details.
As far as performance/street hybrid applications go, we'd be very happy to recommend our product but those looking for hard-core, next-to-no-compliance solutions might be disappointed.
Hope that helps and let us know if you'd like any tech data.
Cheers
Whiteline Jim
Cheers
Whiteline Jim
G'day everyone,
Cheers
Whiteline Jim
Cheers
Whiteline Jim
so I have been checking out your product line. It seems that you offer two lines, Flat out and Whiteline Plus, is that correct?
